Troubleshooting & Support
Hot Topics:
- sound card
- space hard...
- bios upgrade
- sound
- diagram...
- motherboard...
- emachine...
- w5233
- epson 42v...
- dvd cd player
- reboot select...
- manual tk 1300
- pci simple...
- sharp xe a202
- boot disk...
- boot menu
- beeps
- forgot admin...
- change boot...
- forgot password...
- 230 manuals
- restore...
- restore...
- eMachine...
- w3609
- emachine fans
- t6532
- replace power...
- reset
- install...
- View All »
Problems & Solutions
emachines t5212 overheat message then shuts down
Three causes of ovheating:1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed...
where do I plug in a modem in an e-tower 466?...
I had one of these models and the phone modem is built in and not replaceable---I retired mine as it was just too slow at doing things and...
I restored T5048, but now it shuts down and...
Shuts down and restarts the boot process automatically continuously. Try turning it off, then hit the power button and immediately...
The 945GCT-M3 motherboard wireing diagram for the...
power connecter has totally 9 pins on the board but actually we have to use only 8 pins please refer the attached image if you have further...
computer system locked and dont remember password
I hope you forgot the password for your Operating System Log On. If you forgot your boot password of your bios, then this may not be as...
My computer will not show video, no matter what...
Hello, I would do a few things here: Update your web browser to the latest version as well as your media apps. (Windows Media Player,...
emachine w3619 bootmanager missing
the tray can be damaged or if it is not lit at all it has no power or is corrupted..if it is just jammed ..you can try to insert a sharp...
I am trying to restore
emachines does not provide any factory restore option in computer, in fact you might have received factory restore disks when you bought it,...
I CANT FIND PCI DRIVER
just download this software,no need search engine,no more tired of looking anywhere...instantly,it will be in your laptop for several...
The plastic inside one port
how come the the ports are in one pci-e board you have get a new one if one dont work neither will the other its called dual-channel probaly...
my emachines tower does not
Power supply for one, Motherboard for another. E-machines a lot of times the capacitors on the motherboard will bulge out or even crack open...
T5048 windows xp very slow,
The fact that it is slow may or may not be the memory. Did you purchase the correct memory for the computer? I suspect that you did since it...
When the computer starts I get two errors at
Most motherboard used the button pin type of battery for the bios. Specifically, your board used the CR2032 , 3VDC battery. Just be sure...
i need to upgrade the ram memory in my pc so how
Hi, this is quite straight forward. Either side of your memory you a little leaver, push these downward toward the motherboard. Be carefull...
I am working on an Emachines computer. I need to
ECS MCP61SM-GM Version 1.0, connectors on motherboard, http://support.gateway.com/s/MOTHERBD/Shared/4006233R/4006233Rtc.shtml ECS MCP61SM-GM...
Unsolved Problems
it is asking me for
it is asking me for a command
i whant to reboot the etower 600id , i have the
i whant to reboot the etower 600id , i have the cd but it is aking me for a command
Manuals & Guides
TopDo you have a manual for E-Machines etower 600id PC Desktop? - Upload it to FixYa!
Upload a manual for E-Machines etower 600id PC Desktop
Specifications
TopKey Features
Full Product Name:E-Machines etower 600id PC Desktop
Operating System:Microsoft Windows 98 SE
Form Factor:Mini Tower
Processor:Intel Celeron 600 MHz
Installed Memory:64 MB (SDRAM)
Recommended Use:Small Business, Home Use
Processor
Processor Type:Intel Celeron
Processor Speed:600 MHz
Processor Manufacturer:Intel
Processor Upgradability:Upgradable
Max Processors Qty.:1
Motherboard
Bus Speed:66 MHz
Video Output Interface:AGP 2x
Memory
RAM Technology:SDRAM
Installed RAM:64 MB
Installed Cache Memory:128 KB
Max Supported RAM:256 MB
Hard Drive
Hard Drive Capacity:20 GB
Hard Drive Interface:DMA/ATA-33 (Ultra)
CD / DVD
Optical Drive Type:DVD-ROM
Optical Drive Read Speed:8x (DVD)
Other Drives
Floppy Drive:3.5" 1.44 MB floppy
Audio / Video
Audio Output Type:Sound Card
Modem
Modem Type:Fax / Modem
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
137
137 people have viewed this product
- 2 people asked about this product.
- 0 people have added this product. Be the first!
Automatically...
How to Keep...
Computer Repair...
