i having problems getting my playstation 3 to connect with my tv when i connects it only goes on to...
(More)
i having problems getting my playstation 3 to connect with my tv when i connects it only goes on to a small screen what should i do
The led light is flickering fast at front of tv and picture keeps turning on and off or should i say...
(More)
The led light is flickering fast at front of tv and picture keeps turning on and off or should i say tv keep turning on and off standby.
When my head phones are plugged in, it does'nt re direct and stays on normal sound. I am using the...
(More)
When my head phones are plugged in, it does'nt re direct and stays on normal sound. I am using the EXT socket 3 at the side of the TV is this the right way to do it if so do you have any suggestions too why it will not work. Thankyou for your time
workes ok for about 1 hour then right side of screen thin lines start to appear top to bottom half...
(More)
workes ok for about 1 hour then right side of screen thin lines start to appear top to bottom half way across you cant see picture on that side left side is ok turn off for 5min it will work for about 30 min can you help
watching tv all of the sudden shuts off then try hooking up a dvd player i get picture but no sound/...
(More)
watching tv all of the sudden shuts off then try hooking up a dvd player i get picture but no sound/ lost manual
Right after turn it on it show right hand several white and blue vertical lines about 5" wide...
(More)
Right after turn it on it show right hand several white and blue vertical lines about 5" wide and form like a curtain, everything else is fine
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
