Troubleshooting & Support
Hot Topics:
- user manual
- software...
- 633ids drive...
- enter bios
- bios upgrade
- machines
- cd drive...
- 633ids drive...
- restore...
- memory
- manual free...
- boot menu
- cd read rom won
- ew 1078f
- install...
- vxd 032ci
- motherboard...
- change boot...
- escapement
- emachine fans
- sharp display
- forgot password...
- fix sound
- lines screen
- manual
- screen print
- diagram...
- ce 3700 manual
- 5260 driver
- forgot admin...
- View All »
Problems & Solutions
were can I get a free recovery disk for
It wont be free but it will be cheap. Call emachines and request an ew set of recovery discs.
I deleted windows\system\vmm32.VXD on my
You must either recover that file from a backup, copletely reinstall windows, or use the Windows Recovery disk that came with your computer...
can I install 2 hard drives with the etower 633ids
Yes, you can install up to 4 HD drives...
how to connect the hard drive
Remove the power cord, remove the case. Look inside the computer where the hard drive sits in the by and make sure the power cable from the...
how to connect the primary and secondary drives
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up...
someone gave me this pc and i cleaned it like a
This is an OLD pc, This is the only link i could find...
the file in computer missing or corrupted
replace the file, with a new one you can find it on the web
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reg in out registry cleaner
633 which jumper would disable video on board?
You should have a setting in your BIOS. Once you plug in and external AGP or PCI card the BIOS will recognize it and use that one instead of...
how do I reset my computer to take all the viruses
Try to insatll updated mcafee anti virus. Remove as much viruses by mcafee. then download trial quickheal 2009 setup and update it......
motherboard start and freeze at the...
You may have a failed motherboard or power supply. Failure of motherboards (and power supplies) is usually due to breaking capacitors. A few...
i need drivers for netfinity 10/100 ethernet for...
nothing found
EMACHINES ETOWER 633IDS FULL SYSTEM RESTORE?
If it is in original configuration system restore would be on D: drive partition
emachines t5212 overheat message then shuts down
Three causes of ovheating:1) Dust. Dust inside the computer, Dust around the vents, fans, cpu and heat sink. Take a can of compressed...
where do I plug in a modem in an e-tower 466?...
I had one of these models and the phone modem is built in and not replaceable---I retired mine as it was just too slow at doing things and...
Manuals & Guides
TopDo you have a manual for E-Machines etower 633ids PC Desktop? - Upload it to FixYa!
Upload a manual for E-Machines etower 633ids PC Desktop
Specifications
TopKey Features
Full Product Name:E-Machines etower 633ids PC Desktop
Operating System:Microsoft Windows ME
Form Factor:Mini Tower
Processor:Intel Celeron 633 MHz
Installed Memory:64 MB (SDRAM)
Recommended Use:Small Business, Home Use
Processor
Processor Type:Intel Celeron
Processor Speed:633 MHz
Processor Manufacturer:Intel
Processor Upgradability:Upgradable
Max Processors Qty.:1
Motherboard
Bus Speed:66 MHz
Video Output Interface:AGP 2x
Memory
RAM Technology:SDRAM
Installed RAM:64 MB
Installed Cache Memory:128 KB
Max Supported RAM:256 MB
Hard Drive
Hard Drive Capacity:15 GB
Hard Drive Interface:DMA/ATA-33 (Ultra)
CD / DVD
Optical Drive Type:DVD-ROM
Optical Drive Read Speed:2x (DVD)
Other Drives
Floppy Drive:3.5" 1.44 MB floppy
Audio / Video
Audio Output Type:Sound Card
Modem
Modem Type:Fax / Modem
Warranty
Warranty:1 Year
What's your problem?
Fix-O-Meter
1,765
1,765 people have viewed this product
- 14 people asked about this product.
- 13 people found solutions for this product.
- 1 person has added this product.
Automatically...
How to Keep...
Computer Repair...
