3,376 people viewed this product
One very common problem encountered on many Philips models, old and new, In some cases, the SSB boa...
http://www.electronica-pt.com/index.php/component/option,com_rem...
The TV is in some kind of protection mode, the blinking LED show you an error code. Try pressing 062...
Check the audio settings first. Go to its menu and see whether audio is muted or not. If all are fou...
There should be some fault to the digital processor section circuit. It is at the main board. The fau...
Check your power on switch on your TV... IT my be loose... Press power button on TV well to... che...
Usually stems from a short on the power supply board. I have a 37MF337B/37 37" that had the same pro...
Download the service manual to this set by internet. It will have all details.
You have a short on the front end of your power supply board!
Get a better antenna or if possible a outside one--set can only deal with the quality of signal that it ...
The chirp or beep is a indication of a short on a line with fairly high voltage, over in most cases 100...
I would get a professional diagnosis on the set. It could be a power supply fault, or a main board fau...
I would suspect a bad capacitor on the power board. They dont always show any outward sign of being bad...
Have a tip for Philips 17PF9945 17 in. LCD HDTV?
Dear Sir, I've a philips TV chassis 22PFL3405H/12, and my first question is how can I open the...
Phillis 37" LCD flat tv making high pitched noise intermittently. Could this be the power...
En la pantalla se ven lineas de colores verticales, y a los segundos la pantalla queda negra . Tiene...
All colours are gone & ghost images started. What to do?
Hi i have a philips 42 inc. Lcd tv when i turn it on after 5 seconds it goes back off do u know what...
upon bootup of the tv,the sound and video are ok.when it overheats,the display shows only 1/2 of the...
| Key Features | |||
| Full Product Name | Philips 17PF9945 17 in. LCD HDTV | ||
| Also Known As | Philips 17PF9945 17 in. HDTV LCD Television |
| Screen Size | 17 Inch | ||
| Digital TV Standard | HDTV | ||
| Flat Panel Type | LCD | ||
| Display Resolution | 1280 x 1024 pixels | ||
| Display Capabilities | |||
| Aspect Ratio | 16:9 | ||
| Aspect Ratio | 4:3 Enhanced | ||
| Built-in Tuner | NTSC | ||
| Display Format | 1080i (HDTV) | ||
| Display Format | 720p (HDTV) | ||
| Remote Control | |||
| Remote Control | Universal | ||
| Illuminated Remote | Non-Illuminated | ||
| Image Quality | |||
| Contrast Ratio | 350:1 | ||
| Comb Filter | Digital 3-Line | ||
| Pixel Pitch | 2.9 mm | ||
| Brightness | 450 cd/m² | ||
| Viewing Angle | 176 | ||
| Audio Features | |||
| Audio Type | Virtual Surround | ||
| Audio Leveler | With Audio Leveler | ||
| Technical Features | |||
| Picture in Picture | Without PIP | ||
| Sleep Timer | With Sleep Timer | ||
| Energy Star Compliant | Non-Energy Star Compliant | ||
| Connectors | |||
| Headphone Jack | With Headphone Jack | ||
| Front Input Connectors | Composite x 1 | ||
| Front Input Connectors | Audio (RCA) x 1 | ||
| Front Input Connectors | S-Video x 1 | ||
| Screen Text | |||
| OSD Languages | English | ||
| OSD Languages | French | ||
| OSD Languages | Spanish | ||
| Channel Labels | With Channel Labels | ||
| Speakers | |||
| Number of Speakers | 2 Speakers | ||
| Speaker Power | 2 x 3 Watt | ||
| Dimensions | |||
| Depth | 2.6 in. | ||
| Height | 11.9 in. | ||
| Width | 20.4 in. | ||
| Weight | 14.1 lb. | ||
| Warranty | |||
| Overall Warranty | 1 Year | ||
