When switching TV on it does not go to original mode as when switched of, just goes to the digital...
(More)
When switching TV on it does not go to original mode as when switched of, just goes to the digital mode but cannot get freeview have sky and standard analogue channels but have to keep pressing a/d button on remote to access them, but according to manual it should go back to the channel that you switched off at that is (analogue) Also cannot go back to factory setting as per instruction manual,that is by pressing and holding the menu button on the side of the set for more than 15 seconds
after hooking the HDMI cable from PS3 to the Phillips TV, I turned to Mode HD according to the user...
(More)
after hooking the HDMI cable from PS3 to the Phillips TV, I turned to Mode HD according to the user manual. However, there is no signal and screen stays black. It is when I go to PIP mode then I find the picture in HD! Not sure why it shows up there and not the main HD screen? Please help.
I have a number of Philips tvs and when i adjust the volume it remains on screen for a number of...
(More)
I have a number of Philips tvs and when i adjust the volume it remains on screen for a number of seconds can i remove this facility?
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
