20 Most Recent
E-Machines T2082 PC Desktop Questions & Answers
T2082
Power cords and mice you can pickup at almost any computer supply place. The power cord should be no more than $5, and basic optical mouse can be bought for $10 -15. I have one of these machines and I think they are 2004 - 2005 vintage.
Blank Screen
have you changed out the mother board? It could be the processer or the ram is not the right kind.
Cpu upgrade
Hi Keith... here is all I could find on this machine, I assume this is how yours is set up. Component details are almost impossible to get on E-machine units, they just do not provide them.
- Processor Intel Celeron D 356 / 3.33 GHz
- Memory 512.0 MB / 2.0 GB (max)
- Hard Drive 120.0 GB - 7200.0 rpm
- Operating System Microsoft Windows Vista
First, you want to check to see if your proc even can be changed; many of E-machine procs are permanently attached to the motherboard and cannot be removed; this is the cheapest way to manufacture a computer, and E-machines is bottom of the line quality computer (no insult intended, just fact). Since I don't know what CPU socket the T3604 has I can't tell you if the Intel CPU would fit it. Next, I don't know what the Northbridge is running at; if it is less than 1066 there will be a bottleneck and there is no significant gain. At this point, I suggest that you not spend a lot of money on this, better to save and build your own computer. If you are a hardcore gamer looking for high framerates you really don't want this machine. Better to load in more RAM if you have no other options. Here is something I ran across:
http://www.overclock.net/t/763634/what-to-upgrade-emachines-t3604
If I had the above details I could give you an answer.
My emachine t1831-07 keeps getting stuck on green
www.dynamite.com might still sell what you want :> Just kiddding!Try a complete wiping of the hard-drive unless you are doing an upgrade, you will lose all data on the drive. If that doesn't work, you might not be running enough ram memory for 7 to run cleanly on you machiine, go ahead and upgrade.Hope this helps!
Want to restore to beging of time
Remove any DVDs or CDs from the optical drives and then unplug all peripheral devices except for the keyboard and mouse. Click the "Windows" button and then type "eMachines recovery management" into the search box. Click on "eMachines recovery management" in the results list and then click the "Restore" tab. Click "Password Settings" and then type a new password into the text box. Click "OK" and then click "Restore System to Factory Default". Type the recovery password into the "Password" text box and then click "OK". Click "Next" To start the recovery process. Click "Finish" and then wait for your computer to restart. This procedure could take several minutes. Once your computer has restarted, you'll be prompted to create a new user account, enter the date and time and set up the internet settings. or if you are running XP If you set your machine back to
eMachines factory settings, it might help you for a short while but if you don't have effective virus protection your problems will return in short order. You should get rid of this virus with an effective virus remover. You can run Bitdefender's free online scan which doesn't need to be downloaded http://www.bitdefender.com/scan8/ie.html If you know when you got the virus, you can do a system restore to a time before the virus was on your system. This article tells you how to run it from safe mode
http://bertk.mvps.org/html/safemode.html Your best protection in general is a complete internet security suite such as Bitdefender or Norton internet security 2009. More information here
http://www.ask-the-computer-doc.com/comp... If you need to totally rebuild your system and you don't have a recovery disk, contact eMachines to get one. You might also try a Windows repair install if you have the operating system disk. Follow the directions here for XP
http://www.michaelstevenstech.com/XPrepa... Source(s):
http://www.ask-the-computer-doc.com/comp... Hope this helps.
I have aT3830 that wont power on
http://www.geeks.com/details.asp?InvtId=D845GVSR-BO-R I would like you to 'jumpstart' it, and then post back in a Comment. Jump the Soft Power On of the 20-pin ATX main power cable. Power supply plugged into power, 20-pin ATX main power cable plugged into motherboard. Straighten out a paperclip, then bend it into a U-shape. Put black plastic electrical tape around the top of the U. Turn the U upside down. You are going to use the 'legs'. The legs go down in the back of the main power cable's connector. (Where the wires go in) One leg goes down into a socket hole with the Green wire, RIGHT NEXT TO the wire, and MAKE SURE it touches the metal terminal at the bottom. The other leg of the U-shaped jumper wire goes down into ANY socket hole with a Black wire. Contact made is brief. Does the Power Supply turn on? As stated, post back in a Comment.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Computer starts but no diplay shuts down immediate,
Is the power LED on the monitor ON, if not check the power cable connection at the monitor and at the mains.Check the video cable connection at the PC.Try a different working monitor on your PC and see if the monitor works on a different PC (the monitor maybe faulty).
I need a wireing dieagram for the motherboard on a T3065 e machine
You will find (normally in the bottom right) 2 rows of pins sticking out of the motherboard. Some of these will have connections to them with wires coming out and going to the front of your cumputer. Look for a free space usually about 2 or 3 pins, marked PWR, O/I or PSW. Alternatively it may be color coded Blue or Green is usually the color for the power switch. I have attached a picture of an e machine motherboard showign the location of the connectionsOne of hte pins might be marked with a + this can be ignored if you are just connecting the power switch.
