FixYa.com
Meade ETX-125EC  Telescope
All Products > Meade > Telescopes
Problems with Meade ETX-125EC Telescope?
Search inside Meade ETX-125EC Telescope Knowledgebase
Troubleshooting and Support
Solved Problems for Meade ETX-125EC  Telescope RSS Feed Post a New Problem
Loose image when focusing
The shift is bad when i have an object in the center of field of view and then focus, the image will go way out to the...
1 Solution
LOOSE FOCUS SHAFT
On this model the set screw is only to put on or remove the knob from shaft. there is no adjustment.the shaft has good...
1 Solution
Can't get to focus.
My telescope was boxed for 10 months. Now I turn the knob and even without the grub it still will not focus. I turned...
1 Solution
ETX 125 Loose image when focusing
when i turn the focusing knob in and out the image iam loking at also moves around side to side.is this a repair i can...
1 Solution
i need help
how to use the go to feature on my Meade ext-125ec
1 Solution
focusing problem
I can turn manually focusing knob either direction and it will not focus, do you have any info how to resolve this...
1 Solution
Meade ETX-125EC Telescope Problem
Someone connected an incorrect power supply and now the scope will not power up. Are there any circuit breaker/fuse...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Meade ETX-125EC  Telescope RSS Feed Post a New Problem
Software
Durina the time of Dowloading information, the Telescope Turn off. Now we have nothing in the PAD, like the software...
Post a Solution
the telescope will not move
the telescope will not move up and down
Post a Solution
Trouble shooting
the telescope won't turn left and right using the electric controller - the Autostar computer controller. What should i...
Post a Solution
secondary mirror
How do u remove the secondary mirror from an ETX 125. Thanks
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Focal Length1900 mm
Mount TypeAltazimuth
Optical Diameter127 mm
Max Useful Magnificationx 500
FinderscopeOptical
Optical DesignCatadioptrics
Meade Contact Information
Main support number(800) 626-3233
Support FAX(949) 451-1460
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
