20 Most Recent
Olympus Camedia C-755 Ultra Zoom Digital Camera Questions & Answers
I have photos that I
To delete all the pictures, you can use the "
All Frame Erase" function from the camera menu.
For the detailed steps, please refer to the attached images:
Alternately, you can also format the card to delete all the stored pictures.
Hope this solves your problem. For more help and clarifications, please feel free to reply to this post.
Thanks for using
FixYa.
Language option
Selecting the desired language:
1. Set the mode dial to P and press the power to switch to turn on the camera to the ON position.
2. Press MENU button.
3. Press arrows dial buttons to select the MODE MENU.
4. Press arrow dial buttons to SET UP tab.
5. Press arrow dial buttons to select Language.
6. After selecting the language press OK dial button on the middle of the group buttons.
That is all. So you can change the language by this way.
Regards.
Olympus camera problem
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb or 2gb cards are not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Zooming causes shutdown
I think your battery is weak, not holding current or not enough.
Before buying a new camera's battery, try to discharge the battery because most batteries have memory problems.
Find a small light that is rated up to the battery voltage.
Connects two wires to battery and then to light.
When the light goes out, battery is fully discharged.
Now, charge up the battery with the camera's charger
Try it on the camera.
Alexander
[email protected]
Olympus c755
Your backup battery has gone dead. Check your manual to see if it is replaceable, or if it needs to be replaced by a repair shop.
I have a C-750 on my bench now in for repair, and I do not see a customer-replaceable backup battery. I do not know if this applies to the C-755, but the C-750 requires disassembly to replace this cell.
David Millier
Advance Camera Repair
Memory card is stuck in the drive-shuts down automatically
sometimes the card older gets damaged and brakes the only solution is to replace it, if u notice some grease inside u can put some alcohol or eter the last one is better, but be careful don´t put to much, because can damage the obturator, but first of all look into the slot and check if it´s ok, if thre contacts are fine, if so clean it with eter/alcohol, and insert the card and take it out to see if he realise the spring.
Olympus Camedia E10 won't power on with AA NI-MH batteries but works fine with AA ALKALINE, what can I do?
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
How to use zoom on c-860L
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times.
I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
Manual setting of focus
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
