20 Most Recent Olympus MJU 400 Digital Camera Questions & Answers
256MB This is from the specs in the instrucvtion book
Olympus MJU 400... | Answered on Apr 26, 2013
This normally happens when dirt or dust particles get caught between the lens segments. Check for this. If you can't do it yourself, take it to the nearest authorized service center.
Olympus MJU 400... | Answered on May 02, 2012
HI
On the back of your camera there is a button that has a little triangle above it. Make sure the memory card is in the camera. Then turn the camera on. Next you will want to push that little button and the pictures you have taken should come up on the screen. Thank you I am glad I could help you today!!
Olympus MJU 400... | Answered on May 26, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Olympus MJU 400... | Answered on May 08, 2011
30 seconds is quite a long time for a camera on start up but I don't have the start up time specifications for this camera. Now for the orange light flickering after a shot the lights are telling your the pictures is being loaded to your memory card. It still seams like a long time to be loading a picture but I don't know where you has set the quality level of your photo's another thing is formatting the memory card. The memory card needs to be formatted to the camera it is being used in, if this card was not formatted I'm surprised it's working at all. My suggestion would be to download the pictures from the camera to your computer Hard Drive eject or safe disconnect the camera "drive" different computer call it different names. You must stop the card before removing the USB cable.
Once the pictures are on the computer hard drive then format the memory card this will clean all the pictures off the memory card and make it ready for new pictures.
Olympus MJU 400... | Answered on Dec 30, 2010
It's possible that your camera, being 7 years old, was never designed for a 2gb card. You can find cards of all sizes at amazon.com
Olympus MJU 400... | Answered on Jun 16, 2010
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Olympus MJU 400... | Answered on Dec 26, 2009
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either one of those problems will require professional repair. If it hasn't suffered from a drop, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Olympus MJU 400... | Answered on Dec 24, 2009
Hi
You are probably suffering from the most common fault with the MJU 300/400 range of cameras. If you can still see pictures from your memory card when you use the quick view button, then this is a good indication that the software of the camera is operating perfectly. However the camera switches to photo capture mode when the lens cover is moved back. It is a common fault with these cameras that the black plastic armature operated by the sliding action becomes loosened from the case resulting initially in the cover becoming sloppy and causing the lens to keep closing erratically. More importantly the plastic armature which is positioned to operate a tiny Surface Mounted switch can cause the fragile plastic 'nib' to break off. It is this switch that in effect turns the camera on. If this is what has happened, it is the most common fault, there is very little that can be done as a DIY repair unless you have access to speciallised SMD soldering equipment, experience in this type of repair and most importantly a source of supply for the SMD switch. I have as yet been unable to identify the type or supplier myself. The alternative is to take the camera to an authorised repair shop. This is the expensive route but you might be able to keep the costs down by making it obvious that you know what the fault is etc.
some have a view button which you can choose to put in "black mode". happens a lot. take it to your local camera shop if they know anything they should be able to put it right in seconds
Olympus MJU 400... | Answered on Dec 23, 2009
Is the battery old? Have you let it completely discharge from non-use. Batteries don't come back if that happens.
Olympus MJU 400... | Answered on Dec 10, 2009
I Have the same same problem , it happens to be the sliding door playing up ....need to take it to a repairer(Olympus) to fix ...hope this helps
Olympus MJU 400... | Answered on Mar 08, 2009
If you are using an SD card, it could be possible that the Write Protect tab (the yellow tab on the top right) is in the 'lock' position. Slide it back and try again. If this does not work, make sure you are using the card and not the internal memory to store images.
Olympus MJU 400... | Answered on Feb 05, 2009
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Olympus MJU 400... | Answered on Dec 25, 2008
there isnt a quick fix on this tiny motors and switches im afraid you need to send thia to a shop, the home postition sensor is failing nor the motor itself is defective
Olympus MJU 400... | Answered on Sep 29, 2008
Thanks for your reply..fortunately I found the errant disc hiding away on a shelf...Regards Pat.
Olympus MJU 400... | Answered on Sep 26, 2008
I had the same problem with mine after it had been dropped on the ground.  I undid the two screws at the bottom which holds the sliding lens cover on and took the cover off.  Check the small black lever inside.  It might be broken.  I replaced the part from an older model and but the cover back on.  I works fine now.  I hope this helps
i think it's just 'cos of the sheer size of the memory it has to access. mine works quite quickly but when i put in a 512 it takes a lot longer i would not say there is anything wrong - just teh limitations of a device which was designed when even 128MB was a luxury ricardi, shropshire
Olympus MJU 400... | Answered on Aug 28, 2008
Olympus MJU 400 Digital Camera Logo
44 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Mju Olympus
  • Mju Olympus
Most Popular Question
maximum size xd card use in
  • Cameras
