20 Most Recent Olympus Camedia C-3030 Zoom Digital Camera Questions & Answers
The C-3030 uses SmartMedia cards. They're almost extinct, but you should be able to find some at an electronics or office-supply store. The largest capacity is 128MB.
Olympus Camedia... | Answered on May 14, 2013
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Olympus Camedia... | Answered on Dec 20, 2012
I have a possible answer to your problem but FIXYA will not let me send it to you.
Olympus Camedia... | Answered on Oct 11, 2011
Hi!
A simple workaround is to remove the memory card from the camera and insert it in an appropiate card reader connected to your computer. It allows also a higher transfer speed, that's why I allways do so.
Regards,
Bogdan
Olympus Camedia... | Answered on Sep 23, 2011
You can find the software for the Olympus Camedia C-3030 Zoom HERE.
But if you need only the software, you might want to have the newer and
also free Olympus Viewer 2 software.
Olympus Camedia... | Answered on Aug 12, 2011
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Olympus Camedia... | Answered on Jul 01, 2011
Hi, You dont need a software to be able to view the contents of the camera on your computer. Just plug it to the computer using the usb cable and once it has been detected, RIGHT click on your computer's Start button and choose Explore or open windows explorer. From the new window, click on My Computer or Computer from the left pane. Under it, look for he drive associated with your camera and click on it to show the contents on the right. From there, you can now copy the contents of your camera to the local drive of your computer. Hope this helps. Thank you for using FixYa.
Olympus Camedia... | Answered on May 15, 2011
Olympus Camedia... | Answered on Apr 15, 2011
Consider NOT using the USB connection.
Olympus Camedia... | Answered on Apr 06, 2011
I have good news and bad news. The good news is: I can solve your problem! The bad news is: those 17 different types of card do not include yours... almost certainly a SDHC. You need to get a card reader that specifically says that it does SDHC. I've seen USB stick adapter ones for $2.00 in the "dollar store".
Olympus Camedia... | Answered on Feb 01, 2011
If your camera uses a memory card, just use a separate card reader....then you don't need drivers. typrice_109.jpg
Olympus Camedia... | Answered on Jan 25, 2011
Presumably you downloaded this, extracted files and right clicked inf file and clicked install? Did you then reboot and try to connect the camera? Connect then switch camera on?
Olympus Camedia... | Answered on Jan 03, 2011
The date and time (and a lot more) are stored with every image. Any photo printing program should have an option for printing the date and time on the picture (or in the margin or even on the back if the printer is two-sided).
Olympus Camedia... | Answered on Nov 26, 2010
Your camera is long discontinued so you basically have two choices. You can look for a used one on ebay or similar (but they'll all be old and potentially faulty) or you can buy a new replacement camera to fit your colposcope.
If, as I suspect, your camera has been using the Olympus CLA-1 lens adaptor which allows accessories to be attached to the front of the camera, then it's likely that all you need is a camera which has a 43mm filter thread. Unfortunately, many digital compact cameras either completely lack a filter thread or use non-standard sizes these days, but if you contact the major camera manufacturers' customer care teams to explain your requirements, they should be able to suggest a suitable model. I've tried searching on your behalf, but online specifications are frustrating as they usually fail to quote the filter thread size.
In the worst instance, you may need to spend more than is strictly necessary for your needs on a digital SLR and then buy a cheap step-down filter ring on eBay or Amazon (filter threads on SLR lenses are usually larger than 43mm).
You didn't mention the make and model of your colposcope, but it may also be worth contacting the device manufacturer as they may be able to suggest suitable current cameras and perhaps more importantly, which ones may be incompatible with your colposcope.
Olympus Camedia... | Answered on Sep 02, 2010
Use a card reader instead.
Olympus Camedia... | Answered on Jul 09, 2010
You can download a copy to your computer at this address. Just copy and paste it into your browser. http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=521
Olympus Camedia... | Answered on Jan 26, 2010
Your camera probably wants you to format the card in the camera to get it to work properly. This will erase the card so download any pictures first.
Olympus Camedia... | Answered on Oct 20, 2009
go to the menu and look for a date stamp or a clock icon it varies from cameras
Olympus Camedia... | Answered on Aug 02, 2009
Olympus Camedia C-3030 Zoom Digital Camera Logo
65 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
purchace memory card
  • Cameras
