20 Most Recent Philips 13MDTD20 13 in. TV/DVD Combo Questions & Answers
I had exactly the same problem When the TV was switched on all I could see was a flashing green light. After cheching the TV internals and not seeing a problem including the power supply unit which looked and checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons simultaneously i.e. the on/off, the volume, the programme, menu buttons, all of them simultaneously and Plug it into the power supply again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Philips 13MDTD20... | Answered on Sep 22, 2009
Hey
Whenever there is a TV or any electronics problem ...immideatly remove the plug from the adaptor...some times the problems may go worse.....
Number on problem of all electronic
will be in SMPS circute....
first check for the fuse....inside the smps if blown replace it and restart....
but be careful and be alert....check within 1min
if ok .....proceed......if not remove the plug.....
and consult the electrnics guy
Philips 13MDTD20... | Answered on Sep 20, 2009
laser has gone not worth doing to expensive £60.00 plus
Philips 13MDTD20... | Answered on Feb 27, 2009
Hi, EASY :) just a few clicks on Google...... Turn the TV on, press the number 9 on the remote four times (9999) an then press MENU button on the remote too. Thtas all folks !, Sorry for my bad English but I'm from Spain :)
Good luck ;)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=14PT6007/05&slg=ENG&grp=TV_GR&cat=TV_CONVENTIONAL_CA&sct=COMBI_TV_SU#
Philips 13MDTD20... | Answered on Jan 23, 2009
yes this happend to these, its a board fault a quick fix is to open bedroom window and throw out . sorry seriously pull the plug and leave for i hour and it might clear the error if not there is a backup battery in the set it needs changing. regards kirk
Philips 13MDTD20... | Answered on Dec 09, 2008
after replacing microprocesser ST92T195D7B1 all the menu's are ok including english menu .But their is no sound through tv channels. when playing dvd the sound is ok.so i still need some help.
kind regards kingkash
Philips 13MDTD20... | Answered on Oct 05, 2008
the problem is it is not with the tv itself the problem is with the dvd player the lens may need to be cleaned if you can message me i would be glad to help ya
Philips 13MDTD20... | Answered on Mar 20, 2008
my open/close button doesn't work either. my model is 14PT6107S/05
Philips 13MDTD20... | Answered on Jan 15, 2008
reepende a donde vivas si vives en mexico las venden en mercado libre si vives en otro pais em EBAY o en tiendas de electronica y en tu localidad en un desguesadero de electronica si eres usuario mejor lleva tu pantalla con un especialista,y si eres tecnico consigelas en donde ya mencione.
Philips... | Answered on Sep 08, 2019
Applicable codes will be found in a compatible remote control.
Philips... | Answered on Aug 29, 2019
Hi Anonymous, search Google, LCD Panel for Philips TV 55PUT6233 / 56
Keep in mind that replacing the panel has its risks
Good luck in the search
Regards Franco Dosil
Hola Anonymous, busca en Google, Panel LCD para TV Philips 55PUT6233/56
Ten en cuenta que reemplazar el panel tiene sus riesgos
Suerte en la busqueda
Saludos Franco Dosil
Philips... | Answered on Aug 24, 2019
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
Philips... | Answered on Aug 22, 2019
Philips 13MDTD20 13 in. TV/DVD Combo Logo
13 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips tv 20pf4121 doesnt turn
  • Televison & Video
