20 Most Recent Philips 9P5034C 50" Rear Projection Television Questions & Answers
If the fuse at the back is faulty Television dose not work at all. When sound is there but no picture that must be circuit problem.
Philips 9P5034C... | Answered on Sep 10, 2016
Try looking on the back of your tv should be a small square with info & model # on it at least that's where mine was but I have a Mitsubishi. good luck, when you find it, right it on your user manual for the next time you need it!
Philips 9P5034C... | Answered on Nov 06, 2013
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Philips 9P5034C... | Answered on Apr 19, 2013
you should be able to get the remote for your model by sending an email request to [email protected]
Philips 9P5034C... | Answered on Jun 24, 2012
if the chips were replaced and any of the 5.6 ohm protect resistors around them are bad, the set will not turn on.
The simple way to confirm or deny this is to unsolder both chips and see if set turns on, this will tell you if it is convergence or some other issue
Philips 9P5034C... | Answered on Nov 22, 2011
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Philips 9P5034C... | Answered on Apr 17, 2011
This is an old-style tv, one in which the image is produced by 3 small tv tubes and then projected on the screen. Since you have sound it means that the defect is situated in either the video processor and finals or the tubes themselves have either failed due to old age or they aren't powered. To find out which you must open the tv and test it.
Start by removing the back and just look at the tubes: if their necks aren't lit when the tv is on then the tubes aren't powered - you will need to check the contacts on the base of the tubes and reseat all of them (don't forget to pull the plug and wait for 15 minutes before doing that). If the tubes are lit you will need to check the voltages on the electrodes - start with the cathodes. If all the voltages appear to be ok then it's in the video section - find out if the video transistors are powered correctly and operational. If they are then it's the image processor - luckily in this tv it can be replaced , with some effort, individually. You will just need to find and absolute exact replacement.
All of this requires a good electronics experience. If you don't have it then it's time to call a pro.
Philips 9P5034C... | Answered on Feb 28, 2011
Your symptoms sound like the CRT fluid has gone bad in the set. There are three CRT’s and each are cooled with Ethylene Glycol that is clear, but can become contaminated, mostly in the blue and green. You can order a kit with full instructions from a web site that I have used.
Try www.tvrepairkits.com. They carry the fluid kit that you are looking for. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
If you need any further help please reply to this post.
I hope that this helps you with this issue.
Thanks for using Fixya.
asnowman
Philips 9P5034C... | Answered on Mar 29, 2010
This set needs the coolant fluid between the tubes and lenses replaced. This is a very common problem for philips/magnavox projection tv's and should only be performed by a professional so that there will be no leaks. Theis is a complicated repair. Thanks for using fixya.
Philips 9P5034C... | Answered on Dec 27, 2009
Are you using component video?
Sounds like a mixed up wire in the back.
Also, double check the source (ie cable box / vcr ) and see if there is a setitng on that you need to adjust.
Philips 9P5034C... | Answered on Dec 02, 2009
you have a opto isolater on the power deflection board failing its a 8 pin dip pack ic
its on the board at the rear of board on right side there are three ics its the middle one 8 pin
Philips 9P5034C... | Answered on Oct 24, 2009
not worth it, likely been dropped and all the lenses etc are out, or just worn out from a hard life.
Philips 9P5034C... | Answered on Oct 12, 2009
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Philips 9P5034C... | Answered on Aug 09, 2009
Hi, common problem, have a tech replace IC7412, gl, video-tek
Philips 9P5034C... | Answered on Jul 03, 2009
check CRT socket and crt board.
Philips 9P5034C... | Answered on Jun 03, 2009
magnavox "smart sound"
Philips 9P5034C... | Answered on May 30, 2009
Philips 9P5034C 50" Rear Projection Television Logo
65 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
modle9p5034c103 chip replace tv still
  • Televison & Video
