20 Most Recent
Packard Bell (160248-01) Computer Speakers Questions & Answers
Speakers
Packard Bell (160248-01) Computer Speakers with a 12
volt power source worked OK,
Tried a 9 volt and it also worked.
This pair of speakers is grey with a
barrel design. The mounting surface placed flat is approximately 10.25
inches by 3.75 inches. Each end has a rainbow design with a depth of 2.75
inches. By placing with the mounting surface flat on your desk gives you an out
of the floor design. The front edge from the desk to the bottom edge is 1.5
from the surface to the top edge with a 3.75 inch. Suggesting you may mount
them under your desk, on the side by your legs or stand them on each side of
your screen.
I am told they come in white and black also I found them rather large for what I need but your decision is you should be happy before buying a pair.
Need help getting sound from my inbuilt speakers!
Make sure you have the right power source. Amps make a difference, If it requires 1 amp and you are only putting in 200 mA, then you might not have enough "juice". You can test the speakers using an MP3 player or something of similar sort through the earphone jack. If the speakers work, check you sound card functions.
RE: "Packard-Bell speaker power requirements"
I have a power source that cam with similar speakers that is labeled Packard Bell Plug In Class 2 Power supply
Model @ 012-10-1000-07
Input: 120VAC 60 hz 25W
Output 9VDC 1A
BPCS #: 146139
Maybe this will help
How do i connect speakers to PC ?
If you have WS media player its automatic once you connect the speaker jack into the audio hole...dont forget to check if your speakers require power, plug them and increase the volume to an audible level.
If after all above has been done and no sound go to: Control Panel+ sound+ sound and click the drop down so you are able to change the option to windows default...click ok and apply. Then close and re open windows o play sound.
Audio key 256mb lost
The issue quiet short, and I am not sure how to start on a solution, it would be fine if I may need more information so that I can give you a precise solution?
Thank you.
I recently bought the Studio
be sure it is powered and on when you connect it ..and also the driver was installed into computer ...after that if it doesn't detect it ...run the add new hardware wizard from the control panel ..and select the already added feature..and see if it detects it ..If it do not came with a driver ..t means it is a plug and play device and it will be seen and installed auto ..
after that you should see it in the my computer folder as a drive ..(removable ) ..
al so be sure you confirm the connection with the p con the player if it asks ..(or take a look if it has a pc connection mode on menu or like a button feature)
Recording from baby monitor
I am assuming the model you are using is similar or the same as the model I used once. That being the case, you need an external recording device and you simply use the headphone jack to connect the two. You should be able to use your computer and some simple recording software.
