20 Most Recent Philips 9P6040C 60" Rear Projection Television Questions & Answers
Sorry
Recycle it correctly.
Sorry Mark
Philips 9P6040C... | Answered on Mar 23, 2015
Never spray directly on a screen. If the solution seeps into the underside (back etched side of the glass) it could damage the surface. You may have to get to the inside from the rear projection area or lift of the front glass screen and remove it completely. Usually the Rear surface of the screen is etched and can be wiped clean. Go to Bed Bath and get a good streak less windows cleaner. Spray it on a soft cloth and wipe the front and/or back glass. Wipe dry with a CLOTH, not a paper towel, and when dry use a flash light to see any streaks or blemishes left behind. Clean again is necessary. Do not apply pressure, gently clean and try not to cause scratches as they show up when the projection device flashes the image on the glass portion. Put it all back they way it was and enjoy.
Philips 9P6040C... | Answered on Dec 18, 2013
You can change the size through either the menu or a button on the remote usually referred to as "aspect". It should give you 2 or 3 choices for the size. Some cable or DTV boxes also have this feature and may be in conflict so try setting from both until you find the right size. Good luck.
Philips 9P6040C... | Answered on Aug 28, 2013
power on, can hear sound but no picture.
any suggestions
Philips 9P6040C... | Answered on Oct 05, 2010
Try the site www.TvRepairKits.com
They helped me solve my Magnavox problems with one of their kits.
Philips 9P6040C... | Answered on Aug 09, 2009
You will need to replace the two STK392-110 Convergence ICs and also a couple of the 6.8 ohm 1watt resistors. You can get replacement ICs and resistors for your set at the following link and they provide free instructions with pictures.
http://servicemanuals.vstore.ca/
Philips 9P6040C... | Answered on May 01, 2009
you have a convergance problem with your set. How much it cost to fix dont know what area you live in so cant tell you. Could be around 300 to 400 dollars. That is in a shop or someone comeing out to your house to fix.
Philips 9P6040C... | Answered on Mar 03, 2009
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Philips 9P6040C... | Answered on Feb 16, 2009
Is this a DLP or a conventional 3 tube rear projection?
Philips 9P6040C... | Answered on Jan 26, 2009
If your video is shrinking and expanding its the opto IC. You can get a repair kit from www.magnavoxhelp.com
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, dark, etc. You may even see halos around images.
Here are some of the most common symptoms.
  • Screen looks 3D
  • Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Philips 9P6040C... | Answered on Dec 20, 2008
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom:  No Video. Audio is intermittent. Power light still works
Philips 9P6040C... | Answered on Oct 12, 2008
Screen shrinks and expands and wams up after 10-20 minutes and then went out completely? Power light still comes on and remote still works? This is a common problem for this model and is most likely related to a bad chip. A tech will charge you over $300.00 to fix it but you can buy the repair kit including the chip, step by step instructions and repair manuals for under $40.00 if you are willing to do a little soldering. Go to http://www.magnavoxhelp.com/ and enter your model or chasis number and order the kit. This will not fix color problems!
Philips 9P6040C... | Answered on Aug 27, 2008
it is very possibvle that the three lights are not positioned correctly or you may have to change the fluids behind the lights only a technician can do this
Philips 9P6040C... | Answered on Aug 16, 2008
Philips 9P6040C 60" Rear Projection Television Logo
Popular Tags
28 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 30pf9946 12
  • Televison & Video
