20 Most Recent Philips 60PW9383 60" Rear Projection Television Questions & Answers
Thats not dust its the CRT coolant needing replacement. You will notice that the blue and green look the worse which is indicating the CRT coolant needs replacement. If you need further assistance let me know and I will assist
Philips 60PW9383... | Answered on Oct 19, 2011
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Philips 60PW9383... | Answered on Dec 15, 2010
Thats the classis sign that the CRT coolant needs replacement to restore the picture quality. You can get the Phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for the three CRTs plus the CD with instructions.
Philips 60PW9383... | Answered on Jun 20, 2010
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Philips 60PW9383... | Answered on May 07, 2010
Sound with no picture on this model is typically the HVG/Flyback.
Philips 60PW9383... | Answered on Sep 06, 2009
reepende a donde vivas si vives en mexico las venden en mercado libre si vives en otro pais em EBAY o en tiendas de electronica y en tu localidad en un desguesadero de electronica si eres usuario mejor lleva tu pantalla con un especialista,y si eres tecnico consigelas en donde ya mencione.
Philips... | Answered on Sep 08, 2019
Applicable codes will be found in a compatible remote control.
Philips... | Answered on Aug 29, 2019
Hi Anonymous, search Google, LCD Panel for Philips TV 55PUT6233 / 56
Keep in mind that replacing the panel has its risks
Good luck in the search
Regards Franco Dosil
Hola Anonymous, busca en Google, Panel LCD para TV Philips 55PUT6233/56
Ten en cuenta que reemplazar el panel tiene sus riesgos
Suerte en la busqueda
Saludos Franco Dosil
Philips... | Answered on Aug 24, 2019
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
Philips... | Answered on Aug 22, 2019
Philips 60PW9383 60" Rear Projection Television Logo
7 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
picture seems bright blurry
  • Televison & Video
