I carefully moved my 3-4 year old rear projection Philips 51 inch HDTV 1080i about 1 mile away on a...
(More)
I carefully moved my 3-4 year old rear projection Philips 51 inch HDTV 1080i about 1 mile away on a trailer under 30mph the whole way. After the DirecTV installers completed the new installation, every TV works fine except this HD. (Only HD...others are standard) Same HD receiver as before and the installer checked the incoming line with his getup and claimed the signal was perfect. But...I now have horizontal banding over the entire screen at about 1/4-1/2 inch intervals. It does seem to be worse on channels with more reds and oranges than blues and greens or maybe I just see it more on the lighter colors.
0711 is master reset code for 51pp9100d/37? purchased unit from private party need to know how to...
(More)
0711 is master reset code for 51pp9100d/37? purchased unit from private party need to know how to accesss this so we can add the catv box to use pip function... ty
how do i get my Philips 51PP9910 to work for surround sound with my home theatre system without...
(More)
how do i get my Philips 51PP9910 to work for surround sound with my home theatre system without going through a cable box? i want to have regular cable tv, and my playstation to go through it from inside the tv and not each one directly to the surround sound system. I have audio cables on the audio output jacks going to a surround sound system but nothing happens unless i go through a cable box. any help?
During warm-up the blue screen is curved with double images, on normal veiwing a blue ghosting is...
(More)
During warm-up the blue screen is curved with double images, on normal veiwing a blue ghosting is present. When the set is left on for a few minutes and then turned off and an one everything functions fine. The chassis is DPTV410. The error codes 61 and 16 where present in the CSM
i turn on the tv and the only thing that happens is the power light flashes and there is a blank...
(More)
i turn on the tv and the only thing that happens is the power light flashes and there is a blank screen
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
