Philips 50PP9202 50 in. Rear Projection Television
Problems with Philips 50PP9202 50 in. Rear Projection Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Philips 50PP9202 50 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Philips 50PP9202 50 in. Rear Projection Television RSS Feed
View More Results for Philips 50PP9202 50 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Philips 50PP9202 50 in. Rear Projection Television RSS Feed
Answer
I now get lines all over the face of the tv. TV is about 5 years old. Don't know how to open tv to... (More)
Answer
Hi all I need is the setting for all 3 CRT's focus range and voltage coming from the focus block to... (More)
Answer
I can't seem to get my color right , is their some kind of defalt setting ? I also am having... (More)
Answer
(Philips 50PP920217) Bought this TV at an auction so I have no clue what it was doing before it... (More)
Answer
how do i drain crt coolant and what are the steps for replacing the fungus/mold from the 3 color... (More)
Answer
i was wondring if i can get a step by step walk thru on how to change my ic's
Find a Manual
Philips 50PP9202 50 in. Rear Projection Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Philips 50PP9202 50 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Philips 50PP9202 50 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Philips 50PP9202 50 in. Rear Projection Television
Key Features
Screen Size
50 inch
Display Capabilities
Aspect Ratio
4:3 · 16:9 Enhanced
Remote Control
Remote Control
Universal
Image Quality
Comb Filter
Digital 3-Line
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable
Audio Type
Virtual Surround
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
With Headphone Jack
Screen Text
Closed Caption on Mute
With Closed Caption On Mute
Dimensions
Depth
24.3 in.
Height
58.2 in.
Width
44.6 in.
Weight
170 lb.
Warranty
Overall Warranty
1 Year
Philips Contact Information
Main support number1-888-PHILIPS
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
