after a few minutes of use, the screen was flickering and there were lines horizontally appearing on...
(More)
after a few minutes of use, the screen was flickering and there were lines horizontally appearing on the screen
I have 60" projection tv sometimes the picture goes scrambled if you hit beside power switch it...
(More)
I have 60" projection tv sometimes the picture goes scrambled if you hit beside power switch it comes back on. Sound is there just no picture.
I have a Philips 60" projection TV model #60pp9352. The TV turns on but has no sound. It...
(More)
I have a Philips 60" projection TV model #60pp9352. The TV turns on but has no sound. It initially had issues with HVG and both the LSB and the SSM boards have been changed. After changing the boards the TV was working for about 5 hour. The following day after about 30min the sound turned off and a crackling sound was heard in the speakers, audio output, and Headphone ports. All inputs(AV1, AV2, ....) have the same response (Video but no sound). After leaving the TV off for about 3 days, the sound works again, but turns off after 5 min. What could be the problem?Is something heating up?
i have a 42' plasma? i was told i need a new power supply. the green power light turns into a...
(More)
i have a 42' plasma? i was told i need a new power supply. the green power light turns into a blinking red light. where can i get the part that i need?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
