20 Most Recent Philips MX3950 System Questions & Answers
Make sure all the wires are in the right spots, some systems automatically shut themselves off if a connection is wrong.
Philips MX3950... | Answered on Jan 29, 2010
Attach antenna
Philips MX3950... | Answered on Jul 11, 2009
Aside from the xbox360 working via the coaxial digital cable. I got the PS3 to work this way.
I had to use the supplied SCART > (Y-video) (Red-Audio) (White-Audio) cable. Basically plugged this in from the PS3 directly to the MX 3950D Aux (Auxiliary) audio input.
On the PS3 audio settings menu, switched from HDMI to the 3rd option SCART.
Turn on the MX 3950D and set to Aux. Bang, got sound again.
I missed this cause I "assumed" the video/audio cable that came with the PS3 was a HDMI to Audio/Video cable, and didn't even see the SCART port in the back of the PS3. So I thought I didn't want to lose 1080p ..etc etc. Anyways. MX 3950D still good =)
Philips MX3950... | Answered on May 21, 2009
What is the format of the drive? The Philips HTS6510 can only read USB drives that are formatted as FAT16 or FAT32. It can't read files from an NTFS drive. NTFS is the "new file system" for Windows but dates to Windows NT/Windows 2K or so. This is the default format for larger capacity USB drives since more files can be added per folder. See page 51 of the manual for the Philips HTS6510 for the file format specifications for USB drives.
If the file format is FAT16 or FAT32, try a different USB drive and check the current drive in another device. The USB drive may be damaged or may have lost the data it needs to find the files. All flash memory can fail with no warning. Replace a faulty drive. Alternatively, the USB port on the HTS6510 could be damaged. This can happen if too much current flows through the port. If the port is damaged, I don't recommend having the unit repaired unless it is under warranty (1 year). Copy your files to a CD and listen to the music or view the images from that media. The overall cost will be lower.
Philips has the manual on the product support page: https://www.philips.co.uk/c-p/HTS6510_05/-/support . The current link to the manual is https://www.download.p4c.philips.com/files/h/hts6510_05/hts6510_05_dfu_eng.pdf .
I hope this helps.
Philips Audio... | Answered on May 28, 2019
????? ??????? model name:SP050????
Philips Audio... | Answered on May 16, 2019
all these things are deleted through menu setting etc.
Philips Audio... | Answered on May 15, 2019
Hello Nicholas, it would be nice if you commented that audio signals are connected to your Soundbar, in this way I could find the possibility of failure, to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Nicholas, seria bueno que comentes que se?ales de audio tienes conectado a tu Barra de Sonido, de esta manera podre buscar que posibilidad de falla, para buscar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://data2.manualslib.com/pdf5/110/10927/1092650-philips/hts8100.pdf?c627f1691eabddb18405d1975afcf790&take=binary
Philips Audio... | Answered on May 08, 2019
Philips might be a source.
Philips Audio... | Answered on Mar 29, 2019
It is glued together, you can pry it, which will break it, attempt to heat up the glue with a heat gun is your best option
Philips Audio... | Answered on Mar 20, 2019
this is what i have on mine i used a 3.5 mm jack as an INPUT and i also have a set of female RCAs next i will be replaceing the plugs for speakers and putting standard speaker terminals
Philips Audio... | Answered on Feb 21, 2019
Philips MX3950 System Logo
Popular Tags
8 questions posted
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
radio mx 3950d dvd player
  • Audio Players & Recorders
