20 Most Recent
Philips LX9000R System Questions & Answers
Philips lx9000r 25S ome theater system Has
The Access Code is 0000 as default unless it's been changed
I think you'll find if it's not playing Region 2 DVDs that it's the same old Philips fault in that the laser has gone / is going.
My philips lx9000r will not
Hi
The lens of the philips lx9000ris weak and when the lens is weak, the dics will not play.It will say no disc.
You have to replace the lens with a new one.
Thanks
I have a problem with the head of DVD LX 9000R
To my knowledge they are using their own standard IDE DVD+RW writers, get one and simply replace its head. In desperation, if you can't find the exact same model, you could replace the entire optical unit - all you need to do is to remove its case and front plate and connect the data and power cables.
Wont play most dvds
its the player's nature... you have only one option see the encoding which are on the manual and those kine of discs(.mp4, .divx something like this)
The DVD draw cover is stuck opened and the Standby
You can do one thing in this conditions you can resolve your issue by changing the tray with motor lens set other than this you can't do anything because in this case max there will be a damage of lens, so kindly check with this to resolve your issue.
The dvd draw will not open when I press the open/close button.
You can try reseting the unit.
Reset the set to the default factory settings:
All the information stored
(programmes, time and date) will be lost.
1. Disconnect the set from power supply.
2. Press and hold down "STANDBY•ON" on the set and reconnect the set.
3. As soon as "IS TV ON?" is displayed, release "STANDBY•ON."
Hopefully reseting it will clear whatever problem it is having and allow you to once again use your DVD player.
Hope this helps. Good Luck.
Lx 9000r wont play any dvds even previously played
