20 Most Recent Edison DHE65 Dehumidifier Questions & Answers
Dehumidifier runs but does not collect water
Is the condensor unit running ?
9/13/2010 4:01:56 PM • Edison DHE65... • Answered on Sep 13, 2010
Can I hook this up so itd empies directly into the
yes, there should be a bucket that fills with water, on the outside of the bucket, there should be a cap you can screw off, once off you can attach a garden hose to that bucket and the other end goes in the drain.
6/28/2010 6:18:18 AM • Edison DHE65... • Answered on Jun 28, 2010
Edison Professional ACT1805-2500 PA Speaker. I need a manual please, anyone?
Question edited for clarity and typo. Question moved from Dehumidifiers to an Edison Audio category. Nothing on that model, but there are some pictures online. It looks to be an Amazon special. This is the worst Google search result I have seen for a long time! https://www.google.com/search?q=Edison+Professional+ACT+1805-2500 There are some manuals here. https://www.google.com/search?sca_esv=557255143&rlz=1C1QJDB_enCA643CA644&hl=en-GB&sxsrf=AB5stBgOeZZPRbJlylKq5YzeDqKEysEOYg:1692142889631&q=Edison+Professional+ACT+1805-2500+manual&tbm=isch&source=lnms&sa=X&ved=2ahUKEwi4y-G-69-AAxWWDDQIHUl6DaQQ0pQJegQIDRAB&biw=1920&bih=931&dpr=1 ./.
8/15/2023 11:49:13 PM • Edison... • Answered on Aug 15, 2023
0answers
Who is Edison Ogie
Be the first to answer 5/31/2017 2:05:00 PM • Edison... • Posted on May 31, 2017Be the first to answer
Coils freezing up
You need to clean the drain out
3/10/2014 6:36:51 PM • Edison... • Answered on Mar 10, 2014
0answers
Edison Dehumidifier
You didn't say what humidity range you have it set for, or how damp of an area it is dehumidifying. The one in my basement also never shuts off and we have it set for the lowest humidity (meaning we don't want any down there). If you think it should be shutting off you might want to get another Humidistat they are $33.05 at this link, http://www.appliancefactoryparts.com/search/partinfo.php?partsID=278698&modelsID=118670&typeName=dehumidifier
5/23/2008 4:19:00 PM • Edison... • Answered on May 23, 2008
I have an ebac15 dehumidifier. When I moved it there was an oily liquid underneath. Why would this be?
There could be several reasons why you're finding an oily liquid underneath your Ebac15 dehumidifier: Refrigerant Leak: If the dehumidifier is leaking refrigerant, it could result in an oily substance pooling underneath. Refrigerant leaks are often accompanied by an oily residue1\. Compressor Issue: A malfunctioning compressor can cause refrigerant leaks and result in an oily substance accumulating underneath the dehumidifier. Condenser Coil Leak: If the condenser coil is damaged or deteriorating, it may lead to refrigerant leaks and the presence of oil underneath the dehumidifier. Internal Component Failure: Internal components such as seals or tubing may degrade over time, leading to leaks of refrigerant or oil. Improper Handling During Transport: If the dehumidifier was tilted or handled roughly during transportation, it could have caused oil from the compressor or other internal components to leak. Given the potential hazards associated with refrigerant leaks, it's advisable to discontinue the use of the dehumidifier and consult a professional technician for diagnosis and repair.
3/31/2024 6:13:56 PM • Dehumidifiers • Answered on Mar 31, 2024
2answers
Hi, do you know whether the Airforce Dehumidifier model BQWDH-816EAH is a desiccant of compressor type? Can't find the information anywhere. Thank you
The Units are made in the Far East and are often sold under different maker names but retaining all or part of the model number. Here is the manual sold by Evantair. It has a compressor.https://www.manualslib.com/manual/1016879/Evantair-Wdh-816eah.html#manual..
2/28/2024 5:23:57 PM • Dehumidifiers • Answered on Feb 28, 2024
2answers
Ecoair DD1 Classic MK5 Desiccant Dehumidifier BQDD122FW does not work.
Can you give a little more detail about the problem? Is it turning on? Is there just no water collecting?
1/30/2024 7:01:35 PM • Dehumidifiers • Answered on Jan 30, 2024
I have a continuous drain hose attached but the tank keeps filling up. What can I do? The unit is only a few months old and works wonderfully,
'make model (what it is)' first 3 words in every question please. You could have three issues. 1. a drain plug not removed 2. an airlock 3. a blockage caused by biofilm gunk. Nasty stuff. Try blowing air UP the drain hose. ..
1/28/2024 2:26:03 AM • Dehumidifiers • Answered on Jan 28, 2024
I own a active air dehumidifier model is AADHC180P.control panel is not giving the right humidity
I would check the position of the sensor and make sure it is clean and free from debris.
11/9/2023 4:20:38 PM • Dehumidifiers • Answered on Nov 09, 2023
Goldair GD2005 dehumidifier. It starts and stops, runs for 1 sec, stops, and the power light flashes. You can hear the relay cycling as it starts and stops.
Question edited for a lot more clarity, add maker, fix English. It sounds like a refrigeration issue like low gas. There are various idea here, but you probably need to drop it off at a refrigeration service centre. https://www.google.com/search?q=gd2005+dehumidifier+starts+and+stops+working ..
10/22/2023 4:13:29 PM • Dehumidifiers • Answered on Oct 22, 2023
Challenge ram 710 manual
Hello I would like to buy a dehumidifier "Challenge" ram 710. Is there a possibility to connect a little pipe, so it can be runned for 24 hrs, without having to care if the tank is full or not? Thank you for all your answers! Daniel
9/24/2023 12:44:04 PM • Dehumidifiers • Answered on Sep 24, 2023
Haier Dehumidifier says 'bucket full'.
It sounds like the switch needs to be replaced or adjusted. https://www.google.com/search?q=Haier+Dehumidifier+says+bucket+full Need model number. That is needed in all Fixya questions. https://www.google.com/search?q=haier+dehumidifier+parts+list ..
9/6/2023 1:26:48 AM • Dehumidifiers • Answered on Sep 06, 2023
Edison DHE65 Dehumidifier Logo
4 questions posted
Top Edison Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Edison Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Edison Dehumidifiers
Most Popular Question
dehumidifier runs but not collect water
  • Dehumidifiers
