20 Most Recent Philips CDR795 2-Disc CD Recorder Questions & Answers
je ne peux pas gravé le avec cet apparaille
Philips CDR795... | Answered on Oct 17, 2015
hello
if not possibly evil shall open tray chorea and if not that I doubt the engine.
luck
google tras
Philips CDR795... | Answered on Jul 12, 2015
Something is jamming it. Open it up ( if competant to do so) and check for broken plastic.
Philips CDR795... | Answered on Jan 08, 2014
More info pls.
Philips CDR795... | Answered on Aug 14, 2013
Most turntables require a preamplifier ot AMPLIFY the miniscule output of their PONO cartridges and are not usable by anything BUT a specifically-labeled PHONO input, which your CD recorder does not have.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
But you probably need or have other electronics for driving speakers and listening to the CDR. Maybe IT has a PHONO section.
Philips CDR795... | Answered on Apr 19, 2011
With the unit in Standby mode (off), press and hold the Display button. The trays will then unlock.
Philips CDR795... | Answered on Feb 14, 2009
I don't know what you are using to check the caps but in order to find the culprits, it's almost mandatory to have an instrument that will measure both capacitance and dissipation factor (DF) since that is what is killing most of our modern electronics.
If you don't find any caps pregnant or leaking deposits and plan on shotgunning it, I'd start with those with values between 4.7 & 100uFd as these are the most common failures and mostly in feedback paths and are lower voltages.
You can buy them at Mouser Electronics with no minimum charge and 'at cost' shipping.
Good luck-
Philips CDR795... | Answered on Jan 13, 2009
The Philips parts network may be in tattered condition currently because of their abandonment of the US market, turning over everything to Funai, a Japanese maker of miserable junk.
Philips/Funai
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Philips CDR795... | Answered on Jul 17, 2008
Unplug the power cord, then hold the fast forward and fast reverse while plugging the power cord.
Philips CDR795... | Answered on Jul 11, 2008
Disc recover occurs when the power goes off and comes back on halfway through a disc being recorded. Try a new disc? You may have a faulty PCB on the record side.
Philips CDR795... | Answered on Dec 30, 2007
remove the tray out & put the grease on gears under the tray
Philips CDR795... | Answered on Nov 08, 2007
You need to check the file format on music, windows media play does not support their format ((*.ra, *.rm). You can change the format to mp3 or .wav using other software.
Philips Audio... | Answered on Aug 24, 2019
Philips CDR795 2-Disc CD Recorder Logo
21 questions posted
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Audio Players & Recorders
Most Popular Question
philips cdr796 cd recorder
  • Audio Players & Recorders
