FixYa.com
Vivitar Classic  Mini Compact Binocular
All Products > Vivitar > Binoculars
Problems with Vivitar Classic Mini Compact Binocular?
Search inside Vivitar Classic Mini Compact Binocular Knowledgebase
Troubleshooting and Support
Solved Problems for Vivitar Classic  Mini Compact Binocular RSS Feed Post a New Problem
I see two 'tunnels' when using my...
I see two 'tunnels' when using my binoculars, is this normal?
1 Solution
LEITZ TRINOVID 10X22C BINOCULARS
The righthand barrel is a bit loose. Can I remove the small covers on the arms connected to the centre support and...
1 Solution
Tasco OS36 Binoculars battery replacement
The red light in the compass of my Tasco OS36 does not turn on when I push the button on the top of the housing. I am...
1 Solution
Hover Lites radio Controled Helicopter
Hi, I have problem with the new helicopter. The Propella is not working Thanks Patricia
1 Solution
Bushnell repair parts
I have a bushnell custom binoculars Model 11-8362 from the 70's and need the plastic twist up eye cups for them
1 Solution
the left headlight of my xc90 will not...
I brought it to the dealer and they cant figure out either. The bulb is perfect, the fuses are tested and working but...
1 Solution
binoculars
When I look through the binoculars (to watch football) there are two images. How is this fixed? If I have to take it to...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeBinocular
Max Magnification4 x
Lens CoatingFully Coated
Other Features
Focus TypeCenter
WaterproofWithout Waterproof
Field of View241 ft @ 1000 yds
Tripod AdapterWithout Tripod Adapter
Exit Pupil (mm)7.5
Dimensions
Depth4.3 in.
Height1.5 in.
Width3.3 in.
Weight
Weight8.01 oz
Vivitar Contact Information
Main support number805 988-0463
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
