20 Most Recent Samson Airline 77 Professional Microphone Questions & Answers
No sound Samson airline 77
So, if I am understanding you right. As you are talking on the mic you are cutting out as if it is shutting down. If this is the case I would adjust your settings. It sounds like it is clipping from maxing out the input. A protection is cutting you out. Let me know if this is not the case.
1/10/2020 6:11:26 AM • Samson Airline... • Answered on Jan 10, 2020
The headset seems to make pop noises whenever I
As you have written, it sounds like a short or a frayed wire. That is what I would have thought. It could be that the terminal wire has dry jointed and come away from the mic head. You could buy a cheap £15 head set just to check that it is the cables. I use a similar system for a glass blowing studio demonstration area and I am constantly buying replacement head sets. Its a shame there is no complete wireless system on the market. It is always the connections between the bodypack and the headset that are the weakest link.
Theoretically you should be able to connect an MP3 player to the bodypack to prove there isnt a problem from there-on. (I have never tried this but I am now intrigued as to whether it would work)
Its a bit of trial and error and you seem to be following the same path that I would. The only other problem I have had is the aerial on the body pack. I would never have thought such a small aerial could cause popping sounds etc but I have also seen this to be a problem in the past.
Good luck.
9/21/2012 8:47:52 PM • Samson Airline... • Answered on Sep 21, 2012
My Samson Airline 77 wireless
Hi, when loud screeching sounds and static is are heard on sound systems in most cases it is as a result of poor wire connections to the speakers. Check the wires to the speakers most likely the screeching and static is coming from those. Also static could also be caused by mobile devices being close to the receiver. Mobile devices such as internet modems and mobile phones as well as radio transmitting devices could cause static and screeching.
3/2/2011 9:34:30 PM • Samson Airline... • Answered on Mar 02, 2011
Hello I'm Samson. How does this program work?
Hello Sampson People ask questions. Experts answer them. No one get paid, people answer just for the joy to be able to help others. People who use AI Chat GPT to answer, people who answer just for points get deleted. Points are for fun. It isn't a 'program', it is a peer to peer self help website. ADMIN Andrew
  • Answers: 65,884
3/6/2024 5:54:27 AM • Samson Audio... • Answered on Mar 06, 2024
Samson airline cr 77 receiver has no output
There could be several reasons why your Samson Airline CR77 receiver is not producing any output:
  1. Volume levels: Ensure that the volume levels on the receiver are turned up and not muted.
  2. Output mode: Check if the output mode on the receiver is set to the correct mode (balanced or unbalanced).
  3. Cables: Make sure that the cables used to connect the receiver to the sound board are functioning properly and are plugged in correctly.
  4. Interference: Check if there is any interference from other wireless devices operating in the vicinity. This can cause signal dropouts and affect the receiver's output.
  5. Dead batteries: Check if the batteries in the receiver are charged or need to be replaced. A low battery can cause a drop in output.
If none of these solutions work, you may need to contact Samson's customer support for further assistance or consider taking it to a professional technician for repair.
2/26/2023 3:12:41 PM • Samson Audio... • Answered on Feb 26, 2023
I have Samson UHF cr77( chanel N2) i want know what microphone can use
Any that can plug into the unit. The quality of the sound will depend on what you are willing to pay for the microphone. I would take the unit to a shop that sells microphones and they will be able to get you a right one for the unit.
6/5/2021 2:51:48 PM • Samson Audio... • Answered on Jun 05, 2021
Samson Servo 200 Amplifier: Why do my fuses keep blowing?
Some wiring is burnt..ull need to investigate. Causing an overload circuit. Checkout utube or pinterest. Use caution highvolts
5/18/2021 4:12:10 AM • Samson Audio... • Answered on May 18, 2021
How to unmute my Samson Meteor Mic?
There are 2 ways to mute or un-mute the mic:
  1. Push the button on the front of the mic
  2. On the computer, open Recording Properties and go to the Levels tab and click the speaker icon next to Microphone slider.
6/10/2020 9:03:02 PM • Samson Audio... • Answered on Jun 10, 2020
How to set up Samson G-Track Pro?
Hi, have you tried the G-Track Pro on another computer, to see if it repeats the fault? I sent you the link so you can download the user manual of your Samson I hope you can solve the problem Greetings Franco Dosil Hola, has probado el G-Track Pro en otra computadora, para ver si repite la falla? Te env?o el link para que puedas descargar el manual de usuario de tu Samson Espero puedas solucionar el problema Saludos Franco Dosil http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=27347935#
5/26/2019 5:24:41 PM • Samson Audio... • Answered on May 26, 2019
My Samson xp308i won’t even turn on, what can I do to fix this issue.
Here are links to the service and users manual...Good luck! Samson XP308I Service Manual Samson XP308i Owner Manual
5/31/2018 10:13:54 AM • Samson Audio... • Answered on May 31, 2018
Samson Airline 77 Professional Microphone Logo
7 questions posted
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Samson Audio Players & Recorders
Most Popular Question
samson airline 77 wireless
  • Audio Players & Recorders
