20 Most Recent
Acer Brand 14.1 WXGA Matte Laptop Replacement LCD Screen(Not a Laptop) For Acer Aspire 4330 Series Questions & Answers
My computer screen turns blue and restarts window vista
Hi jjlishus,I see you mentioned that you are having issues with you computer going into a blue screen then it restarts. You can try to boot into safe mode to see if Windows Vista will Load without having the bluescreen and if it will not shut down or restart, from Safe Mode, try and do a system restore to a data where the problem has not happened yet.From there-on see if the issue will still happen or noGetting into Safemode:restart PC keep on tapping F8 on your Keyboard this will prompt you options, Look for Safemode then press enter this should bring up the safemode screen.If during the loading of safemode and still happens are any error show up or it goes to a blue screen, you can try going into safemode with command prompt.to get to safemode in command prompt just do the same as ging into safemode and select safemode in command prompt.once in the command promptType CHKDSK , then press enter it should check the system for 5 mins or so depending on your PC/Laptops speed.if still the issue is the same reformatting or restoring your windows back to defaults may fix the issue.I hope that this will help,mvincentc
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
Acer aspire acc 603g uw30 turns on but turns back off. Help
This issue could be caused by several factors, including:
- Overheating - check if the laptop's fan is working and if the vents are clear of dust and debris.
- Low battery - if the laptop is not plugged in, try charging it.
- Corrupted software - try performing a hard reset on the laptop or booting into safe mode and running a virus scan.
- Hardware failure - if none of the above solutions work, the problem could be a hardware failure such as a failing battery or a damaged power supply. Contact Acer Support for further assistance.
