20 Most Recent Sanyo DS27590 TV Questions & Answers
2answers
C 03 won't go away, Sanyo crt tv model DS 27590
Use your remote to get into the menu. You must key into the remote the fact that you do not want the channel reminder on. It is that simple. Be patient you will find this.
9/16/2013 2:24:44 AM • Sanyo DS27590 TV • Answered on Sep 16, 2013
How do i get pip on a ds27590 without a remote
The original remote will have the PIP button/buttons on it.
11/4/2012 4:34:20 PM • Sanyo DS27590 TV • Answered on Nov 04, 2012
LINE HORIZONTAL
replace vertical IC..
2/23/2012 12:15:45 PM • Sanyo DS27590 TV • Answered on Feb 23, 2012
I cant change the input on my tv and have no remote. what do i do?
We'll with out more info i cant help you but just to say go get a universal remote.
12/9/2011 12:39:22 PM • Sanyo DS27590 TV • Answered on Dec 09, 2011
Can't change the input on
Find a Universal Remote at BestBuy. You should be able to program this remote, with the manual included, to your TV.
8/26/2011 7:09:47 AM • Sanyo DS27590 TV • Answered on Aug 26, 2011
I can't get my tv
Does the TV has the "INPUT", or "SOURCE" button?
Try CH UP/DOWN button also.
What is the make and model of the TV?
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: www.interliquidparts.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
7/18/2011 3:50:03 AM • Sanyo DS27590 TV • Answered on Jul 18, 2011
How do I get this tv on video input. I don't have
It's been a few months, so I hope that you have gotten this resolved. But if not, or you still have some questions, here are some steps to go through. The link below will walk you through programming your DISH remote to the tv. This way, you will be able to change that input with just the DISH remote!! Hope this helps.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer service
1/21/2011 10:32:56 PM • Sanyo DS27590 TV • Answered on Jan 21, 2011
Describe your sanyo moddel number DS27590Problem,
Hi there
Check the set to see if it has a source or A/V button. If not, the only thing that you can try is to scroll with the channel buttons up down buttons to see if you can get to the TV channels.
It is likely that you have already tred that:) If that has failed you, then you WILL need to remote to do this. I am sorry to say that this is the only way to get there. You can purchase a remote online from here
Not the only solution you have, in light of the impending change from analogue to digital... you could put your money towards a digital set top box and solve the remote issue at the same time. Check out what you can get from here. They start at less than $50, and could plug into the set you have eliminating the need to change it out of AV mode. You also get extra channels :)
Happy to answer any questions that you may have about it. Cheers
regards
robotek
6/19/2010 11:44:04 PM • Sanyo DS27590 TV • Answered on Jun 19, 2010
Cant get both a VCR & DVD player to work on a
Well if you could gain access to the inside if the set you could locate the Video's Composite Input, and there you could simply "Tap In" there, and run a Coax. OUT for the Video?DVD IN, and similarly, find the Audio's Input, and do the same for that. Then you could, simply NOT provide a signal, IE: Turn on & use, the VCR/DVD. And NOT supply a signal from the VCR/DVD. Instead supply the signal via YOUR leads, and it will NOT know the difference, and display what is being fed into it.
3/13/2010 4:56:15 AM • Sanyo DS27590 TV • Answered on Mar 13, 2010
Sanyo tv channel stuck
A POSSIBLE solution. I have the same stet...got it used, but it's in good condition.
It was stuck on a channel. I went iinto the menu and fiddled with the channel programs and "deleted" the channel and now I can freely change channels.
By the way, I could use a manual for this ...got one?
5/17/2009 6:57:51 PM • Sanyo DS27590 TV • Answered on May 17, 2009
Have SANYO COLOR TV - Model # DS27590 - trying to find the codes so I can program my GE universal to work with it.
I found the codes by going on line to various sites. I have two TV's a stereo, a DVD/VCR player that I wanted to program a universal remote for.
As far as how many devicces one universal will handle...I don't have the answer yet.
Thanks.
5/17/2009 6:54:13 PM • Sanyo DS27590 TV • Answered on May 17, 2009
No Audio
Most likely it pulled hard enough to cause some bad solder connections on the botton of the 4 pin...try to unsolder and resolder the connector and reconnect the speakers this should fix you up.
2/5/2008 1:31:07 AM • Sanyo DS27590 TV • Answered on Feb 05, 2008
Sanyo TV power cord removal Model DP19649
It unplugs.https://www.amazon.com/POWER-CABLE-SANYO-DP19241-DP26670/dp/B019XGHRO8orhttps://directtvparts.com/sanyo-tv-dp19649-power-supply-1av4u20c38500-dac-12m069-2995321500/
4/3/2024 6:15:09 AM • Sanyo Televison... • Answered on Apr 03, 2024
Sanyo 55" inch Television. Where can I buy a replacement stand for it please?
Question edited for clarity. I doubt it is 55' feet, so I made it 55" inch. :>D No model given, 'Sanyo 55" is just one model in a range ver 20 years. You could go the universal route? https://www.google.com/search?q=Sanyo+55%22+inch+Television+replacement+stand or Google Sanyo (model) replacement stand ..
11/19/2023 3:52:11 AM • Sanyo Televison... • Answered on Nov 19, 2023
2answers
What is the regulator of sanyo crt tv model st-21g1
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://schematicscom.blogspot.com/ http://electrotechnician.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given.
10/19/2023 3:02:11 AM • Sanyo Televison... • Answered on Oct 19, 2023
Televison & Video Logo
Popular Tags
27 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
c 03 go away sanyo crt tv model ds
  • Televison & Video
