20 Most Recent Sanyo AVM-2506 TV Questions & Answers
You have a short somewhere causing the power supply not to start. Most likely a shorted horizontal output transistor and maybe a flyback transformer which caused the transistor to short. It would have to be checked out by a technician to find out exactly happened. Stargazer
Sanyo AVM-2506... | Answered on Mar 27, 2013
U need an ipad audio/video connector. One end is the plug at the bottom of the ipad, the other end is a red/white/yellow tv connector. Get a genuine apple one, not one made by other companies, or they wont work, apple has blocked 3rd parties from certain items, and thats one of them. It costs $50 new, or you can find it on ebay used for alot less, just make sure its not a cheap knockoff and its the real one.
Sanyo AVM-2506... | Answered on Mar 03, 2013
Get RCA cables they come in 2 or 3 conductors, Yellow andWhite for Mono and Yellow, White and Red for stereo connection.Connect the one side of the Yellow cable to where it saysVideo OUT on the DVD.
Connect the other side of the Yellow cable to where it saysVideo IN on the TV.
Connect the one side of the White cable to where it saysAudio OUT L on the DVD.
Connect the one side of the White cable to where it saysAudio IN L on the TV.
(optional) Connect the one side of the Red cable to where itsays Audio OUT R on the DVD.
(optional) Connect the one side of the Red cable to where itsays Audio IN R on the TV.www.aaatvservice.com
Sanyo AVM-2506... | Answered on Jan 26, 2012
The TV needs to be degaussed.
There is an automatic degausser built in but it may NOT be strong enough.
Try this: Turn off the TV and let cool for 10 minutes. Then turn on for one minute.
Repeat the previous sequence until screen is clear of blotches.
The cooling period re-arms the degausing circuit.
If this doesn't fix it adequately, you need to find a TV repairman that has a degausing coil... these are getting a bit rare now. It would take him ten minutes with the coil to fix it.
Sanyo AVM-2506... | Answered on Dec 25, 2009
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Sanyo AVM-2506... | Answered on Mar 06, 2009
That doesn't mean anything
Sanyo AVM-2506... | Answered on Dec 05, 2008
As It only makes noise when there is no signal (without an antenna).clearly indicates that there is a problem in sound IF SECTION or loose contact in that section. your audio section section is ok as you get noise signal when there is no signal. also check remote control setting.
Sanyo AVM-2506... | Answered on Oct 03, 2007
Hi no u can't copy to DVD..u can record to video tape..cheers.
Sanyo Televison... | Answered 10 hours ago
Again;The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.
Sanyo Televison... | Answered 3 days ago
fixya doesnt carry hard copies try manufacturer or online search
Sanyo Televison... | Answered on Sep 09, 2019
Televison & Video Logo
Popular Tags
18 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
need schematic cm29kf8
  • Televison & Video
