My Sanyo DS31590 turns on but when it turns on the screen ratio is in 16:9? How do i get it to full...
(More)
My Sanyo DS31590 turns on but when it turns on the screen ratio is in 16:9? How do i get it to full screen????
My RCA TV has a horizontal line across the middle, about 1 to 2 inches wide. The audio is fine. I...
(More)
My RCA TV has a horizontal line across the middle, about 1 to 2 inches wide. The audio is fine. I unplugged it for about 15 minutes then plugged it back in but this did not fix the problem.
CH 3 on top right of display will not shut off - HELP. do not have original remote, using cablebox...
(More)
CH 3 on top right of display will not shut off - HELP. do not have original remote, using cablebox remote
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
