Sanyo PDP-32H1A 32 in. Plasma Television
Problems with Sanyo PDP-32H1A 32 in. Plasma Television?
Troubleshooting and Support
Solved Problems for Sanyo PDP-32H1A 32 in. Plasma Television RSS Feed Post a New Problem
poor picture with hdtv Hitachi 37HDL52...
the tv works fine on video inputs(yellow) , but not properly using the component inputs from the cable box or the dvd...
1 Solution
remote code
I purchased a polaroid flat screen TV last winter from Walmart. Recently I subscribed to UVerse. I need the code to...
1 Solution
blurry screen
I have a Philips model 36PT832027 and the screen is blurry. Any ideas? Thanks!
1 Solution
Tint
Hello, My plasma LG Tv is getting reallt green, which means the tint is not working well. I've tried to control it...
1 Solution
UK TV History Freeview Channel
We have a new digital TV set and are usually able to access all the channels, however, since Monday 15 October the UK TV...
1 Solution
Codes
I would like the codes for the proper setting for the TV as listed below. My cable man was not able to reset the unit...
1 Solution
42" philips plasma flat panel...
I have a blue color bleeding in from the left side of the screen. It appears that when there is a white color that...
Post a Solution
Unsolved Support Problems
Unsolved Problems for Sanyo PDP-32H1A 32 in. Plasma Television RSS Feed Post a New Problem
remote
dog jumped up on the bed and hit the remote, now the tv will only turn on or off. also can only do a anolog scan when...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Screen Size32 inch
Flat Panel TypePlasma
Display Resolution852 x 1024 pixels
Display Capabilities
Aspect Ratio16:9
Image Quality
Contrast Ratio400:1
Brightness650 cd/m²
Output Color16 million colors
Viewing Angle160
Audio Features
Audio TypeStereo
Dimensions
Depth11.81 in.
Height22.2 in.
Width40.08 in.
Weight55.12 lb.
Sanyo Contact Information
Main support number(800) 421-5013
Email supportsupport@sanyotv.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
jimbo4026 Wiz
1 solutions
Ask Me
bluegreen Wiz
1 solutions
Ask Me
henlopen Wiz
5 solutions
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
