I have a Sanyo DRW1000. I am trying to watch a DVD but the channel light keeps flashing CH03 and...
(More)
I have a Sanyo DRW1000. I am trying to watch a DVD but the channel light keeps flashing CH03 and the DVD will not play. Please help ASAP! Thank you.
I am using a Sanyo DRW-1000. When I EasyDub a videotape to a DVD, the only player that will play the...
(More)
I am using a Sanyo DRW-1000. When I EasyDub a videotape to a DVD, the only player that will play the DVD is the Sanyo that I copied it on. Is there something I'm doing wrong? According to the manual, if I use EasyDub, it should record in a format the can be played on most DVD players.
Sanyo DRW-1000: I am using DRW-R dvd's to record from TV and old video tapes. The recording starts...
(More)
Sanyo DRW-1000: I am using DRW-R dvd's to record from TV and old video tapes. The recording starts and runs for approximately 30 seconds and then stops, giving me a message stating, "Recording stopped due to failure recording file information." Can you help diagnose to problem?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
