FixYa.com
Vector VEC-248 Bagged Vacuum
All Products > Vector > Vacuums
Problems with Vector VEC-248 Bagged Vacuum?
Search inside Vector VEC-248 Bagged Vacuum Knowledgebase
Troubleshooting and Support
Solved Problems for Vector VEC-248 Bagged Vacuum RSS Feed Post a New Problem
I have a feeling the original problem was...
I have a feeling the original problem was a result of vacuuming up dog hair (I have 2 huskies), but I always kept the...
1 Solution
Unable to Extract Water
I am able to shampoo but the unit is not extracting the water from the carpet.
1 Solution
Black And Decker Gw150 Forgotten How To...
I have had this model for several years but have not used for a while. I was wondering if you could help me start...
1 Solution
Oreck Vacuum troubleshooting
My Oreck Upright has started spitting out what I want it to suck up. I'm going to try replacing the belt, but someone...
1 Solution
Windsor Sensor 12 Vacuum No Power
i know I have power down to the last quick disconnect in the housing base. I take off the cover today and I have circuit...
1 Solution
help needed pronto!!
im making a science project ..which need a vacuum cleaner.how can i make the vacuum cleaner to blow out instead of...
1 Solution
Kirby G6 Shampooer
I need instructions as to how to put the shampooer together and if there is a way to make it compact enough to do...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Feature
Dirt CaptureBag · Wet/Dry
Motor
Amperage3 Amp.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
