20 Most Recent Toshiba Satellite A25-S208 Laptop AC Power Adapter (15V/8.5A 110Watts) by Amstron (Generic) AC Adapter Questions & Answers
How can you bypass the power-on password
You need to take or send the laptop to a Toshiba Service Center to have the password erased. You may have to prove ownership of the machine. You may also be charged for the service if the laptop is no longer under warranty.
4/2/2014 2:56:02 AM • Toshiba... • Answered on Apr 02, 2014
How can i change my toshiba e-studio 263cs language from garman to english
Hi , Please follow the below steps -start menu -control panel -language -add a language -select language English -Open Button -Select the English region you want -Add Button
4/11/2024 5:54:15 AM • Toshiba... • Answered on Apr 11, 2024
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code: * Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error. *Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly. * Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error. * Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM • Toshiba... • Answered on Mar 26, 2024
Toshiba Satellite S55-A5275 will not boot up.
Joseph was using AI Chat GPT4 to answer questions and they are deleted because they are just guesses by an AI Bot and not specifically targeted to the OP question. Disconnect from the mains. Remove the battery. Press and hold the On button for 2 full minutes, timed. This will perform a very low level power reset for your power disconnect.
Toshiba laptop not starting up
Tom's Guide Forum https://forums.tomsguide.com > threads > toshiba-lapto... Aug 10, 2015 - First do a hard reset, remove the battery and AC adapter then press and hold the power button for 20 seconds. Turn it back on and see if gets ... 1 answer · Top answer: Hi, First do a hard reset, remove the battery and AC adapter then press and hold the power button for 20 seconds. Turn it back on and see if gets ... Toshiba Laptop not boot ' Tom's Guide Forum Dec 17, 2018 my toshiba laptop isn't start. how to fix it - Tom's Guide Forum Nov 16, 2018 Satellite will not run on battery power. - Tom's Guide Forum Dec 2, 2020 Toshiba satellite Laptop won't start after restart and goes to ... Jun 27, 2017 More results from forums.tomsguide.com Here is help on your error message. https://www.google.com/search?q=STOP+CODE%3A+ACPI+BOIS+ERROR BIOS Reset https://www.google.com/search?q=Toshiba+Satellite+S55-A5275+reset+bios General Toshiba Boot issues https://www.google.com/search?q=Toshiba+Satellite+S55-A5275+will+not+boot+up ..
2/28/2024 7:34:49 PM • Toshiba... • Answered on Feb 28, 2024
Codes for toshiba remote CT 90232
It isn't the codes for the remote that matter, it is the television that you want to operate. HOWEVER, this particular remote is custom made for one Toshiba device only!
Toshiba CT-90232 Factory Original Remote Control for TV's
Amazon https://www.amazon.com > Toshiba-CT-90232-Factor... Toshiba CT-90232 Factory Original Remote Control for TV's ; Compatible Devices. Television ; Connectivity Technology. Infrared ; Controller Type. Button Control. Rating: 4.9 · ‎7 reviews · ‎US$14.99
11/11/2023 6:46:06 AM • Toshiba... • Answered on Nov 11, 2023
Ct 90343 manuel Toshiba remote control
The Toshiba site I am providing a link to offers yet another link near the bottom of the page for downloading the manual to this remote. It also appears that the remote is purchasable and that even alternatives to it are provided. Here is the link: https://www.replacementremotes.com/toshiba/buy-ct-90343-ct90343-75017769-tv-tv-remote-control
11/4/2023 9:51:44 AM • Toshiba... • Answered on Nov 04, 2023
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D. If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM • Toshiba... • Answered on Oct 11, 2023
Lenovo Yogo 6 is asking for a password to the Toshiba memory for the harddisk security. How do I find the password without taking the laptop apart?
Hard disk security passwords are typically impossible to find or bypass without the right password.If the Toshiba memory is asking you for a password, kindly check If the laptop arrived with any manuals, they may contain the password or instructions on how to reset or retrieve it. the other option If a user's password is forgotten, several hard drive manufacturers offer master passwords that can be used to open a disk.
8/11/2023 11:04:52 PM • Toshiba... • Answered on Aug 11, 2023
Toshiba DP5022C SDM phone message setting and voice retrieval - urgent need.
Try the Reset on page 100 of the manual for 5000 series Initialize Telephone Settings This function resets all Programming Mode option settings to their default setting. 1. Press 3+6+9+Hold (simultaneously). 2. Press Mode soft key. 3. Press Msg button. 4. Press Hold. 5. Press Vol 'Up' button. 6. Press Msg 7. Press Hold 8. Go off-hook, then on-hook to exit the program mode https://www.compuvoip.com/documents/ug-dp5000.pdf ..
6/13/2023 6:56:40 PM • Toshiba... • Answered on Jun 13, 2023
What is The purpose of USB input on a Toshiba DR430?
5/1/2023 7:50:06 PM • Toshiba... • Answered on May 01, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
  1. Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
  2. Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
  3. Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
  4. Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM • Toshiba... • Answered on Mar 02, 2023
Anyone know of a fix for the Toshiba Thrive AT100-100 Google login Link no longer working?
This says you can delete the Google login requirement. What happens sometimes though that the software gets upgraded and leaves the hardware behind. I just retired an old iPod because of this. https://www.google.com/search?q=Toshiba+Thrive+AT100-100+Google+login+Link+no+longer+working ..
2/24/2023 2:18:42 PM • Toshiba... • Answered on Feb 24, 2023
What happened when Toshiba laptop shows alt+ctrl+del?
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
2/22/2023 11:34:41 PM • Toshiba... • Answered on Feb 22, 2023
2answers
My toshiba laptop displays an expected error occured. Error Code 0xc0000034 during booting window
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop. The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file. You can try the following steps and can try to resolve this issue: 1. Boot into the Windows Recovery Environment (WinRE) 2. Launch the Command Prompt. 3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd". 4. Press Enter and follow the on-screen instructions. Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
2/3/2023 11:39:14 PM • Toshiba... • Answered on Feb 03, 2023
Hello, Engineer, good time. It's a Toshiba laundry model 742 and 5. That A.E. 62 A.M. Thanks for the guidance.
I have no idea who you are addressing, but it is no one here at FIXYA dot com. This is your only post here. https://www.fixya.com/users/ahmadaly-andyarya ..
1/26/2023 7:10:16 PM • Toshiba... • Answered on Jan 26, 2023
3Com Megahertz 3CXEM566 B 10 Mbps LAN+56K Modem PC Card Driver For Windows 98SE
https://www.driverguide.com/driver/detail.php?driverid=5372&si=9ea320d50a226c79eb7fb572e0673dd0
Try this link...I just confirmed that it does exist.
If you have any issues, Try using a Microsoft or a 3Com universal driver.
Last but not least, simply go on eBay for a vintage LAN card...that includes a driver CD that runs on Windows 98SE.
If you need further assistance, just reply after trying those possibilities.
I'm "A+" Industry Certified PC Repair Tech. If you can't find one in a box with driver disc, maybe I have some LAN cards.
Does this need an ISA or PCI slot?
12/13/2022 7:33:59 AM • Toshiba... • Answered on Dec 13, 2022
No channels have been added yet message on toshiba tv connected to tivo
12/4/2022 5:59:08 PM • Toshiba... • Answered on Dec 04, 2022
Toshiba PX1524E-1HKO, flashing blue/red light
If you're seeing a combined blue and red light on your Toshiba PX1524E-1HKO laptop's hard drive, it means that there is a problem with the drive and it isn't being recognized by the computer. This could be due to a number of issues, such as a loose connection, damaged data cables, or a failed hard drive. If you're hearing no sound coming from your hard drive, it's a pretty good indication that it isn't spinning. This could be due to a number of issues, such as a failed motor or a damaged data cable. If you're not sure what the problem is, the best course of action is to take the laptop to a qualified technician or computer repair shop to have them take a look at it. They'll be able to diagnose the problem and let you know what needs to be done to fix it. I hope this helps!
11/22/2022 4:44:16 PM • Toshiba... • Answered on Nov 22, 2022
2answers
I have lost the instructions on how to set the time and date for a digital multi clock GH120A, please tell me how
https://m.blog.naver.com/PostView.nhn?blogId=mobile_app_top&logNo=220570562627&proxyReferer=https://translate.googleusercontent.com/translate_p?hl=en&prev=search&sl=ko&u=http://m.blog.naver.com/mobile_app_top/220570562627&depth=1&rurl=translate.google.com&sp=nmt4&xid=25657,15700022,15700186,15700191,15700256,15700259&usg=ALkJrhgAAAAAXRePT_E1IEH3FJYm7TS9LAEefyLAgoL5 Visual Think December 16, 2013 23:09 Add neighbors Body Other Functions For the GH120A / GH-120A, Multi stopwatch / table clock / stopwatch / stopwatch timer, etc., Just have an alarm function, a small digital watch with a stopwatch function. This watch, I think there are so many users that I can often see at someone's house, and I think it will be difficult to find the manual later. sometimes, I do not think it's inconvenient for someone to read this manual. Below is the manual. 1. Button Description - MODE : Each time the button is pressed, the sequence changes as follows. ; Current time ? stopwatch ? alarm setting ? time / day / calendar setting ? current time - RESET : When the stopwatch function is activated ; STOPWATCH STOP - RESET STOPPER TO 00:00 ; When the stopwatch is started - On the screen, the first stop is displayed one second, and the second stopwatch is running internally. (It can be useful when measuring 1st and 2nd records when running 100m) At this time, press the START / STOP button and press the RESET button again to display the last second - START / STOP ; When the stopwatch function is activated - Start or stop the stopwatch function ; Time display function - Date display ; When setting alarm or time - Function to adjust set value (time / minute increase, date increase, etc.) - Back button ; Press once to activate the backlight for 3 seconds (keep lighting while pressing) - Back round switch ; When the switch is turned off, the alarm sound and the button sound are turned ON (ON character display state is ON) ; When the switch is raised, the alarm sound and the button sound are turned off (OFF character is OFF) 2. Feature Description - current time / date / day setting ; Press MODE button 3 times in time display mode ? If you press START button, ? Pressing the RESET button (minute blinking), pressing the START button increases the minute ? Pressing the RESET button (time flickering, pressing the START button increases the time, Change AM / PM after 12 hours ? Press RESET button (date blinking), START button ? Pressing the RESET button (blinking the month), START button ? Pressing the RESET button (blinking day), START button ? Press the MODE button to complete the setting. - Stopwatch (stopwatch) ; Changed to the stopwatch function with the MODE button pressed once (0:00:00) in the time display mode. ? Press the START / STOP button to turn the stopwatch on and off (However, if the RESET button is pressed during the stopwatch operation, the stopwatch stops, but internally, The second clock is still running, press the START / STOP button once, When the RESET button is pressed, the second stopwatch is stopped) - Alarm function ; Press the MODE button twice in the time display mode (the flashing hour part appears on the screen) ? Timed by START / STOP button ? Pressing the RESET button (blinks for a minute) ? Split by START / STOP button ? Press the MODE button to enter the time display mode (create a bell shape on the screen) ; Disable / set alarm function If the RESET button and the START / STOP button are touched simultaneously, the bell disappears and the alarm is canceled. (Press again the RESET button and START / STOP button again to display the bell shape and activate the alarm function) - SNOOZE ; When the alarm sounds, pressing the RESET button completely turns off the alarm, ; When you press the START / STOP button (bell blinks) ; After the alarm is turned off for a while, the alarm sounds every 4 to 5 minutes. ; To turn off the alarm completely, press the RESET button. - Hourly time signal notification ; It is a function that sounds once every hour, ; While in the time display mode, press the MODE button while holding down the RESET button. ; When pressed, ; If all the day of the week display is visible on the screen, the time notification function is ON, ; OFF state if no day of the week is displayed on the screen - Backlight function ; Press the round button on the back once to activate the gauge for about 3 seconds (press and hold to continue) - 12/24 time system change ; Press MODE button 3 times (second blinking) ? Press the RESET button twice (at the time) ? Press the START / STOP button once to alternately display AM / PM / 24 hour display with increasing time ? Press the MODE button after setting is completed. -------------------------------------------------- -------------------- This concludes the GH120A User Manual (manual) posting.
11/14/2022 2:33:13 AM • Toshiba... • Answered on Nov 14, 2022
Toshiba Satellite A25-S208 Laptop AC Power Adapter (15V/8.5A 110Watts) by Amstron (Generic) AC Adapter Logo
1 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
bypass power password
  • Computers & Internet
