Using Starp dv-rw340u. I've got a dvd-rw with recordings on it, do I have to finalize it before I...
(More)
Using Starp dv-rw340u. I've got a dvd-rw with recordings on it, do I have to finalize it before I can playback in another dvd player?
trying to set up with sony str-dh500 receiver, kdl-46w3000 lcd, and Comcast HD cable box. The sharp...
(More)
trying to set up with sony str-dh500 receiver, kdl-46w3000 lcd, and Comcast HD cable box. The sharp has no hdmi jacks so trying to utilize component set up and can't access the digital signals very well. Any suggestions??
when I record, a message comes up "finalizing please wait" but this process doesn't seem...
(More)
when I record, a message comes up "finalizing please wait" but this process doesn't seem to finish, the disc will then play back on this recorder, but on nothing else.
My Sharp DV-RW340U DVD Recorder/VCR Combo will not keep correct time. Once set, it goes until it...
(More)
My Sharp DV-RW340U DVD Recorder/VCR Combo will not keep correct time. Once set, it goes until it hits 12:00 am or pm, then it just picks any time it wants, which makes recording almost impossible.
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
