20 Most Recent Sharp 27H-S60 TV Questions & Answers
Maybe the program was erased. go to menu and press the auto search program,,, check the bad solders around the tuner. or its possible that the tuner is bad.
Sharp 27H-S60 TV | Answered on Aug 15, 2014
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Schematics of many popular TV circuits are given. I assume it might help you. Surf the site with patience.
Sharp 27H-S60 TV | Answered on Mar 19, 2014
Hmmm, you'll need that original, there. See if you can find one, and maybe even just borrow one to get what you're after...accordianman
Sharp 27H-S60 TV | Answered on Nov 27, 2013
Hi
Your tv set may have an overload in the supply line. Check its rectifier diode and filter capacitor. Another approach is to check if the DC supply line of the switch mode controller IC (UC4842 for exemple).is present (10/12V). If these are OK, replace the switching MOSFET transistor and check the source resitor for open circuit.
Sully
Sharp 27H-S60 TV | Answered on Sep 28, 2013
You may have power supply trouble
Sharp 27H-S60 TV | Answered on May 15, 2013
Send your email address to me by Fixya, and get back a copy of the schematic by return mail.
Sharp 27H-S60 TV | Answered on Nov 29, 2012
The problem is a vertical deflection issue, it means the picture from top to bottom has collapsed. The set will require two or three capacitors and an ic and it is quite fixable.
Sharp 27H-S60 TV | Answered on Feb 07, 2011
Hello
If your TV has provided with audio out RCA type sockets, from which you can feed its audio to any amplifier, and can listen trough it. For that you have to buy an RCA connector cable. OK.
Sharp 27H-S60 TV | Answered on Nov 22, 2010
hi that specific model does not have a headphone jack
Sharp 27H-S60 TV | Answered on Mar 16, 2010
You'll need to take it to a repair shop. There are high voltage capacitors inside a television which will hold a charge even after all power is removed. I would highly advise against making this repair yourself.
Sharp 27H-S60 TV | Answered on Dec 24, 2009
Try changing the 503F horizontal resonator,it maybe faulty
Sharp 27H-S60 TV | Answered on Nov 07, 2009
Televison & Video Logo
50 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
mi tv no enciende solamente una vez
  • Televison & Video
