20 Most Recent Sharp 25L-S100 25" TV Questions & Answers
Without its remote control, you can't get into its menu. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
Sharp 25L-S100... | Answered on Mar 09, 2014
1085, 1094, 1103, 1105, 1384, 1483
Sharp 1004, 1009, 1011, 1025, 1064, 1077, 1078, 1081, 1097, 1099, 1153, 1157, 1274, 1298, 1311, 1312, 1362, 1375, 1378
Sharp 25L-S100... | Answered on Jun 14, 2012
Your closed captioning has been activated. Please remove using original remote menu.
Sharp 25L-S100... | Answered on Jan 15, 2011
Several 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Sharp 25L-S100... | Answered on Nov 28, 2009
These instructions are from the model 25R-S100 but should work for you.
1)Press MENU to access MAIN MENU screen.
2)Press CH UP (8) or DOWN (9) to move the selection to “PARENT CONTROL”.
3)Press VOL (+) or (–) to access PARENT CONTROL mode, then “PARENT CONTROL V-CHIP BLOCK” is displayed.
4)Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message “INPUT SECRET No.” disappears.
Sharp 25L-S100... | Answered on Aug 29, 2009
Probably the best way is to contact SHARP directly. The owner's manual can be downloaded from SHARP's homepage for free.
Sharp 25L-S100... | Answered on May 03, 2009
its very easy on the t.v and press on channel up or down on your tv. u will get the screen
Sharp 25L-S100... | Answered on Dec 11, 2008
try to buy a new remote control or if not available to market try to use the universal remote control you can buy in electronic supply .before you buy check first the model if covered if not try to contact the products manufacturer.
Sharp 25L-S100... | Answered on Nov 06, 2008
first check all RGB drive if have a normal voltage and sync signal if normal maybe the picture tube have damage ,try to replace the new one. gud luck
iv'e run into this before, you have closed caption text 1,2,3 or 4 on. this is different than the normal "cc" cation. just go into your menu & turn off closed caption.
Sharp 25L-S100... | Answered on Dec 27, 2006
Hi Nathaniel, search the internet for the remote control, by Sharp model, otherwise it will be very difficult
Regards Franco Dosil
Hola Nathaniel, busca en internet el control remoto, por modelo de Sharp, de otra manera sera muy dificil
Saludos Franco Dosil
Sharp Televison... | Answered Yesterday
Sharp 25L-S100 25" TV Logo
18 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Televison & Video
Most Popular Question
sharp tv channel lock
  • Televison & Video
