It works when it wants and then it goes on and off until I disconnect it and some times goes on...
(More)
It works when it wants and then it goes on and off until I disconnect it and some times goes on working others it takes a while... any solutions?
when turning on tv it just it like it hisses and goes off ,then you turn it on again clicks and turn...
(More)
when turning on tv it just it like it hisses and goes off ,then you turn it on again clicks and turn off. this start to happen after the tv connector broken off,thanks alot for that solutions.
My son turned on the television a while back and the power switch fell into the television. We...
(More)
My son turned on the television a while back and the power switch fell into the television. We didn't worry too much because we could still turn on the tv with the remote but a couple days ago the remote stopped working and now we cannot turn the tv on. We bought a jensen JR400 universal remote but to programme it you have to turn on the television. Can we programme the remote without turning on the tv? The codes on the manual for the sharp tv are 0093 & 0688. My tv is a sharp 25 " (25NS100) Can you help?
* cannot get Sharp 25N - S100 to work properly with Bright Cordless Headphones from Brookstone: Mod...
(More)
* cannot get Sharp 25N - S100 to work properly with Bright Cordless Headphones from Brookstone: Mod # Phones: RF-H80 & Mod # Trans: RF-T80
buenas tardes srs , les escribo desde honduras ,por que tengo un problema con mi tv ,tenia...
(More)
BUENAS TARDES SRS , LES ESCRIBO DESDE HONDURAS ,POR QUE TENGO UN PROBLEMA CON MI TV ,TENIA CONTRASE?A Y SE ME OLVIDO ,QUERIENDO QUITARSELA ENTRE A MODO SERVICIO ,LUEGO SALI DE ALLI ,,,,.. Y AHORA QUE ENCIENDO LA TV NO CAPTA LA SE?AL DE CABLE ,NI DE AIRE ,SI ME PUEDEN AYUDAR LES BOY A ESTAR MUY AGRADECIDO ,,,
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
