FixYa.com
Jetway PM800BMS Motherboard
All Products > Jetway > Motherboards
Problems with Jetway PM800BMS Motherboard?
Search inside Jetway PM800BMS Motherboard Knowledgebase
Troubleshooting and Support
Solved Problems for Jetway PM800BMS Motherboard RSS Feed Post a New Problem
pci slots not working
my pci slots are not always working or reconised i have a sound blaster audigy soind card and most of the time it works...
1 Solution
Identify older Suttle motherboard
I have an old Motherboard with AMD processor. It is supposed to be a Shuttle brand. I would like to find the model...
1 Solution
audio driver
audio driver not found on the motherboard support,my motherboard is Asrock .everytime i try to install the audiodriver...
1 Solution
Linhai 260 scooter - Oil? Water
Could someone please give me a couple minutes to explain to me where the oil - water, etc.... go on this scooter? I have...
2 Solutions
motherboard
i too have the WinFast 6100M2MA-RS2H MoBo on a system i bought a few yrs back. i recently got a new case and rushed into...
1 Solution
MoBo Winfast 6100M2MA-RS2H
i have the same motherboard as you and after moving to a new case i can not remember the way the power switch connecters...
1 Solution
power sw, reset sw, HDD led motherboard...
i am tryin 2 repair a computer, but as soon as I started i found that the following motherboard connectors were not...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Form FactorMicro ATX
CompatibilityPC
ChipsetVIA PM800 / VT8237
Compatible ProcessorsIntel Pentium 4
Front Side Bus Speed800 MHz
Technical Features
Expansion SlotsPCI x 3 · AGP x8 x 1
Integrated Input/Output PortsSerial Port x 1 · PS/2 Mouse x 1 · PS/2 Keyboard x 1 · Parallel Port (ECP/EPP/SPP) x 1 · RJ45 Lan Port x 1 · Floppy Port x 1 · USB 2.0 x 8
Storage Controller Type(s)Serial ATA x 2, DMA/ATA-133 (Ultra) x 2
South Bridge ChipVIA VT8237
RAID SupportSATA RAID 0 · SATA RAID 1
Processor
Max supported CPUs qty1
Socket TypeSocket LGA775
Memory
Max Supported RAM2 GB
Memory TypeDDR SDRAM
Supported RAM Speeds400 MHz · 266 MHz · 333 MHz
Number of Memory Slots2 x 184 Pin DIMMs
Audio / Video
Audio OutputLine Out · 5.1 Channels
Video InterfaceAGP 8x
Integrated Graphic CardIntegrated Graphic Card
Audio InputMicrophone Jack · 1 x Line In
Video Out Ports15 Pin D-Sub VGA port x 1
Integrated AudioAC'97 Audio Codec
On Board Graphic ProcessorS3 Graphics UniChrome Pro
Communication
Networking TypeEthernet, Fast Ethernet
Other Features
Package Qty1
Chassis TypeDesktop
Other FeaturesHyper Thread Technology Ready
Fans3 x 3-pin fan headers
Dimensions
Depth9.61 in.
Width9.61 in.
Warranty
Warranty2 Years
Jetway Contact Information
Main support number510-857-0131
Email supportandyh@jetwaycomputer.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
