Sharp 64LHP5000 64 in. Rear Projection Television
Problems with Sharp 64LHP5000 64 in. Rear Projection Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sharp 64LHP5000 64 in. Rear Projection...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Sharp 64LHP5000 64 in. Rear Projection Television RSS Feed
View More Results for Sharp 64LHP5000 64 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Sharp 64LHP5000 64 in. Rear Projection Television RSS Feed
Answer
It is a rear projection HDTV (no hd hooked up to it) When I first turn it on it looks great for... (More)
Answer
I turned on my tv and the red and green in the picture were seperating. I tried to move the lines in... (More)
Answer
we have a 42" 8 year old tv which keeps flicking through channels does anyone know what the... (More)
Answer
My TV is in standby mode, when power swich pressed it seems to start but goes back in standby in 2-3... (More)
Answer
The television is a Sharpe HDD, the digital television has worked for since new (Jan 2006). The... (More)
Answer
On the 64LHP5000 that has the a convergence miss-alignment display what is the part number that I... (More)
Answer
Can't access the Digital tuner mode. Going to the Digital menu, input and DTV at the top of remote... (More)
Find a Manual
Sharp 64LHP5000 64 in. Rear Projection Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
The Fl231 PROBLEM(CONVERGENCE NOT IN CUSTOMER MENU) ITC22 chasis
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and... written by willtab
Updated! Convergence Problems & Solutions - With example photos
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV... written by Ecollier2012
How To Fix A Convergence Problem
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen... written by Ecollier2012
Distorted Video - Convergence Problems - 3D Looking
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the... written by Ecollier2012
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for 64LHP5000 64 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Sharp 64LHP5000 64 in. Rear Projection Television
Write a review:
Rate this product:
Would you recommend the 64LHP5000 64 in. Rear Projection Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Sharp 64LHP5000 64 in. Rear Projection Television
Key Features
Screen Size
64 inch
Audio Features
Sound Leveler
With Audio Leveler
Technical Features
Picture in Picture
With PIP
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
