Sharp 65DR650 65 in. Rear Projection HDTV Television
Problems with Sharp 65DR650 65 in. Rear Projection HDTV...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Sharp 65DR650 65 in. Rear Projection...
Troubleshooting and Support
Solved Problems for Sharp 65DR650 65 in. Rear Projection HDTV Television RSS Feed
View More Results for Sharp 65DR650 65 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Sharp 65DR650 65 in. Rear Projection HDTV Television RSS Feed
Answer
Someone told me it might be my ballest. How do you replace this part and where is it. My tv is a... (More)
Answer
where I can order COLORWHEEL for SHARP 65dr650 ,thank
Answer
Hello. I have a Sharp 65DR650 The TV works fine until couple of days ago. When it turns on, and... (More)
Answer
I git it almoast all the way off . The bottom is still attached. Help
Answer
my Sharp 65dr650 picute is rather dull, and hazy. Is ther any way to sharpen the pic. Ihave a brand... (More)
Answer
trying to access service menu for sharp t.v model 65dr650..tried method where you unplug hold down... (More)
Answer
"42PF7220A/37phillips plasma red light blinks 7 times wont power up what is this signal"h
Find a Manual
Sharp 65DR650 65 in. Rear Projection HDTV Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Sharp 65DR650 65 in. Rear Projection HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Sharp 65DR650 65 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Sharp 65DR650 65 in. Rear Projection HDTV Television
Key Features
Screen Size
65 inch
Display Format
720p (HDTV)
Digital TV Standard
HDTV
Projector Technology
DLP
Display Capabilities
Built-in Tuner
NTSC · ATSC
Audio Features
Audio Type
Virtual Surround
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
