20 Most Recent Sharp CD-XP7700 CD Shelf System Questions & Answers
Check and make sure you hook up the speaker wires correctly to the stereo, they are color coded. This unit does not have manual equalizer settings.
Sharp CD-XP7700... | Answered on Mar 27, 2008
Google (sharp)(spc344)(manual) without parens.
Sharp Audio... | Answered on May 15, 2019
  • Set the TIME/RUN/ALARM switch to TIME
  • Press the HOUR button repeatedly to set the hour
  • Press the MINUTE button repeatedly to set the minute
  • Set the TIME/RUN/ALARM switch to RUN
Sharp Audio... | Answered on Mar 25, 2019
Maybe something's wrong with the motor of the system. If you can, try to disassemble the product and look by the CD tray panel or the objects by there, try some force to push it out, if there's still a problem, then maybe a well-known professional that knows a lot about electronics can give you further instructions or information.
Sharp Audio... | Answered on Feb 28, 2019
Google (sharp)(cd-pc4900)(manual) without parens.
Sharp Audio... | Answered on Feb 12, 2019
Your laser diode on the reader head is either dirty or no longer operational, try cleaning the laser diode, if accesable, very gently with an ear bud in a circular pattern, if that doesnt sort the problem it will have to be repaired by a technitian.
Sharp Audio... | Answered on Feb 11, 2019
If you unplug it from the mains for over 24 hours the in built battery that holds the setting you have put in to it should be out of power so when you plug it back in it should have returned to factory settings don't be tempted to just switch it off on the power button as as long as it is plugged in the power keeps going to its internal electric. Circuits
Sharp Audio... | Answered on Jan 13, 2019
Have you tried holding in the timer button in for several seconds..? Some systems require pushing 2 buttons at the same time.. to disable timer.. and switching to manual reset..!
Sharp Audio... | Answered on Jan 06, 2019
Sharp CD-XP7700 CD Shelf System Logo
1 questions posted
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Audio Players & Recorders
Most Popular Question
music plays but vocals weak
  • Audio Players & Recorders
