20 Most Recent Dyson DC25 Animal Bagless Upright Vacuum Questions & Answers
Air filter is not getting air flow.air must pass thru filter or it will pop off.I placed filter against exhaust end of shop-vac ( NOT SUCTION END) untill I got air coming out.
Dyson DC25... | Answered on Nov 10, 2018
There is probably some dirt or debris in the moving parts causing a restriction. The parts may have some wear or abrasion too.
Dyson DC25... | Answered on Nov 03, 2017
I called Dyson because I had a similar problem. When I pushed the red button down on my dc25, but it would not stay down. The vacuum would turn on when the button was pushed down, but of course when I let go of it the vacuum would shut off. The helpful telephone tech. Recognized the symptom right away and told me to push down on the button fully and let It flick up like a lighter. I about fell off my chair when that worked right away! Anyways for what it's worth, she said sometimes the mechanism in the buttons gets consnarlitated (my tern, not hers!) and this resets the spring.
Dyson DC25... | Answered on Jul 19, 2017
Make sure the screws holding the two halves of ball together are tight
Dyson DC25... | Answered on Mar 19, 2017
If the brush bar motor is running try putting on a new belt. If the motor is not running it may be the main switch, the switch that activates when you recline the handle, the motor itself or a loose wire or connector somewhere. Check the connection between the vacuum and the power head. If power isn't transferred properly the motor will not run.
You have to closely check all these areas to find the problem.
Dyson DC25... | Answered on Mar 10, 2017
Remove the torx screws that hold the two halves of the ball shell assembly together, then the ball halves can be separated and removed from the vacuum. Take note of how they come apart and how they line up su you can reassemble them properly.
Dyson DC25... | Answered on Feb 05, 2017
First check the cord for proper voltage, if that's good check the switch. If still good, cjpheck cord from switch to motor, if all is good check the motor.
Dyson DC25... | Answered on Jan 16, 2017
Empty the vacuum dirt container and clean the filter.
Dyson DC25... | Answered on Apr 19, 2016
Your vacuum has a thermal reset built into the motor. If it is getting to hot it will shut off and won't turn on until it cools down. This is a sign of a clog somewhere or the filters need to be replaced. If you are getting dust building up on the vacuum that is an indicator the filters may need replaced.
Dyson DC25... | Answered on Apr 17, 2016
Hi Dan, it's Jack at Dyson.
I'm sorry to hear you're having difficulty releasing your DC25's wand, but this is likely to be simple to resolve. It probably just means that the hose was twisted around when you last replaced the wand on the machine - allowing the hose to unwind will free up the wand. Just follow these steps:
I'm confident this will help, but if you'd like any further guidance after you've given this a try, you can reach our experts directly by calling the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Dyson DC25... | Answered on Mar 01, 2016
Hi Ronald, it's Allan at Dyson.
This might be an easy fix or you might need an engineer to visit you and make a repair.
Please have a look at the video first.
If you continue to have difficulty, please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
Many thanks,
Allan
Dyson DC25... | Answered on Jan 21, 2016
We have a DC65 Animal, the extension tube on the hose would not slide into the top of the handle.
The solution:
1. Slide the hose into the cradle on the handle
2. Push the tube down close to its stowed position
3. Near the bottom of the hose, gently push the hose against the handle with one hand and then push the tube down with your other hand
4. Close the cap on the top of the handle
Dyson DC25... | Answered on Sep 02, 2015
Check w/YouTube w/ model number for info.
Good luck!!
Dyson DC25... | Answered on Aug 09, 2015
Hi Mrs Killick, it's Jack at Dyson.
To resolve this, try removing and replacing the post-filter, as shown in our filter wash video guide below:
When replacing the filter, make sure you push it firmly into place, until you hear a click from the red locking catch.
If you continue to have difficulties after you've given this a try, please contact the Dyson Customer Helpline directly as I'm confident we can help you with this. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dyson DC25... | Answered on Jul 30, 2015
Dyson DC25 Animal Bagless Upright Vacuum Logo
210 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Etronix
Level 1 Expert
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
remove ball from dyson dc 25 animal
  • Vacuums
