lvm-37w1 . sound works but picture is completely scrambled. The screen has horizontal lines moving...
(More)
lvm-37w1 . sound works but picture is completely scrambled. The screen has horizontal lines moving up and down quickly. Used to happen here and there, but now it doesnt go away. TV worked fine all day yesterday.
LVM-37w1 has no picture but sound while playing Killzone 2 video disappeared but still had sound....
(More)
LVM-37w1 has no picture but sound while playing Killzone 2 video disappeared but still had sound. Switched the input to YPRB for cable box still problem.
Hi have a lvm-37w1 westinghouse lcd tv it powers on only displays a picture when input a/v or s...
(More)
Hi have a lvm-37w1 westinghouse lcd tv it powers on only displays a picture when input a/v or s video is selected. When ypbr 1 or ypbr 2 is selected it says no input detected on the screen red and green colors all over screen short lines going horizontal distorting the screen. when menu is on screen there are 8 lines running vertical with muticolored dots on the menu it does show a picture stays on for 5 min. or more. if nothing is connected to input tv goes off to amber light 19 sec. after 53 sec turns off screen. Where can I post a picture I think it would help, set is 2 years old does this sound like a power supply problem? power supply is making a noise when set is in standby. Its quiter when set is on and not in standby . Noise is coming from one of the tranformers on power supply. Im sure of this cause i have set apart power supply cover off. help is appreciated thank you
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Anyone with AKAI problems can download their service manuals at http://esi.fox-international.com. Just select the product type and a list will...
written by Kongsberger
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
