20 Most Recent
BenQ WIFI USB DONGLE MP780ST - 5J.J0614.021 Pre-802.11n Wireless Adapter Questions & Answers
I set a WEP key for the USB, now it's not allowing me to connect, Is their anyways to reset the WEP key of the dongle ? Please Help me.
If it's a standard WIFI dongle it would have come with an installation disk or on-board self installing drivers and (usually) a WIFI app which I presume you used to set the WEP key. If it's a modern one you will be using a MINIMUM of WPA2 and TKIP or AES encryption. Try running the setup app again with one of these settings. The app SHOULD give you the choice of setting up encryption & passwords using windows instead (windows zero config usually) by right clicking on wifi symbol in bottom R of screen. I find that more reliable. Check the maker's spec for the relevent protocols. Good Luck.
I want to transfer photos from dongle to laptop
If you have a micro-memory card installed in the stick, when you plug in the usb stick in your laptop, windows (XP, Vista, 7 & 8) should automatically instal the device with a drive letter for the memory card coming up in 'My computer' along with installation of all the WIFI drivers. This may take several minutes.
How do i transfer photos from computer onto adongle
very simple my Dear , just plug your dongle to a usb port, go to the place where your picture are. then open my computer, open the dongle , right click the picture name or icon, then copy and click in the dongle windows then right click inside and paste.try it is easy as 1+1=?try , i know you will do it!!!
Repair power button BENQ G2400WD
It is possible to bridge to another power supply. There are simple tutorials on YT to help and the process is not very invasive, if you do not wish to harm the current bezel. I was unable to find a switch online to match the model number. Maybe try something close enough to match.
