20 Most Recent
Avocent CPS 1600 Networking Switch Questions & Answers
I can't configure my CPS1600
the CPS600 is controlled and configured with the java based vConsole software. vConsole is provided by Avocent. I personally haven't worked with Avocent hardware much myself, but from what I can tell CPS1600 is designed for a UNIX based network. It should work on a windows networks as well, but you may need to do the CCM firmware conversion or update the CPS firmware to enable the device to communicate with a windows machine. I would recommend to forget about using hyperterminal and try the vconsole software, and if your still having trouble, then go for the firmware update and the ccm conversion as a last resort. Here is the link to the Avocent site, you should be able to find all the necessary software & firmware there. If you do end up needing a Unix system to configure the device, you should be able to get away with using the knoppix livecd linux distribution. Its a bootable cd with a fairly user-friendly version of linux.
www.avocent-europe.com
- Shawn
How can I reset Avocent Cyclades ACS6016 Switch login name & password through Consol login
- Connect to the switch console port using a serial cable and a terminal emulation program like PuTTY.
- Power on the switch and wait for the login prompt.
- Press the "Ctrl + C" keys to enter the bootloader.
- Type "configure" at the bootloader prompt and press enter.
- Type "set password" at the next prompt and enter a new password.
- Repeat the process for changing the login name.
- Type "save" at the bootloader prompt to save the changes.
- Type "reboot" at the bootloader prompt to reboot the switch and test the new login credentials.
2/12/2023 2:57:18 AM •
Avocent...
Answered
on Feb 12, 2023
Avocent kvm monitor flashing red light
So it's the monitor that flashes red? I would try the monitor on a PC to determine if the monitor is good. If not, replace monitor. If monitor works on a PC but not the KVM, power cycle the KVM. Depending on the model you may be able to do a hard reset. On other models you can access the KVM via IP to determine if there is an issue with the KVM.
3/27/2019 4:27:17 PM •
Avocent...
Answered
on Mar 27, 2019
Login my gmail account
https://accounts.google.com/ServiceLogin?service=mail&passive=true&rm=false&continue=https://mail.google.com/mail/&ss=1&scc=1<mpl=default<mplcache=2&emr=1&osid=1#identifier
6/3/2015 11:13:45 AM •
Avocent...
Answered
on Jun 03, 2015
