20 Most Recent
Verbatim Corporation Products - External, USB 2.0, 500GB Capacity, Black - Sold as 1 EA -... Hard Drive Questions & Answers
My external hd wont start.
click start control panel
administrive tools ,computer management ,device manager look through all
of your devices if you see a yellow question mark?or exclamation mark
! or red x
right click to reinstall
drivers or
if you can see your usb but
its not working
ports(com&lpt)right
click update driver
sometimes the wires inside
the cable will be damaged due to bending or stretching or placing heavy
equipment upon the cable,
just replace the cable of
the hard disk, when you plugged the external disk drive you got that
windows could recognize the USB device change the cable everything should work
fine again,
check
the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust
build up on them dust will cause static and a lot of unforeseen problems also
make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the
problem you might have to install a usb 2 or 3 card they are cheap and easy to
install you can buy these on Ebay very cheap if this solution does not work and
you might need one
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280406610810&ssPageName=STRK:MEWNX:IT $1
+ $2.46 postage worlwide
You might get these on Ebay
im not sure which country you are in this might guide you to one
you could get this on Ebay
if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal
login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration
password ,bank card /credit card phone numbers home/mobile ,email adress
and a postal adress
be very specific when you
type in the search
always ask questions?
before you make a purchase and keep the email/s for security reasons if the item
arrives and its not as described
you will even see the
pictures of your item so you cant make a mistake and get them home delivered
hope
this helps
8/8/2011 12:29:31 AM •
Verbatim...
Answered
on Aug 08, 2011
My computer does not reconise
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
6/24/2011 7:35:31 PM •
Verbatim...
Answered
on Jun 24, 2011
About License under software manager
use linux mint 21.3 Cinnamon Edition. I see in the software manager under licence, where it say changing is not allowed. what is the meaning of it? Please tell me. (Everyone is permitted to copy and distribute verbatim copies of this license document, but changing it is not allowed.)
4/19/2024 3:12:17 PM •
Verbatim...
Answered
on Apr 19, 2024
My Verbatim External hard drive Model 47672 just won't power up all of a sudden. How do I go around fixing it, using, etc?
The device is USB powered and the first test is to see if it opens on another computer and if not, another cable. If it does not work, the next thing to know is the probability of being able to get the unit operating again is very slim. Those devices use SMT components and they require very specialized service and diagnostic equipment. That is the reason that these drives come with back up software. You need to back up the back up. There is a slight chance that you may be able to remove the drive from the housing and plug it into a computer directly, of use a universal cable to activate it. Keep in mind that the drive has a lifespan.
4/20/2020 12:48:34 AM •
Verbatim...
Answered
on Apr 20, 2020
Dvd player keeps saying wrong region code
You only get to make four or five code changes and, for copyright reasons, thats it.
You can download Anydvd from Slysoft.com and it will nest in your desk top, and remove all dvd codes as you load. The dvds then run "Region Free"
They will copy with Dvd shrink and so your back ups are region free as well.
2/13/2020 2:23:24 PM •
Verbatim...
Answered
on Feb 13, 2020
Verbatim USB1T external drive
Assuming it’s powered on, do you hear the “usb” sound when you connect it to the computer? If not, try a different usb port, or a different cable. If you hear the sound, check for the disk in “computer management”. It may need partitioned or formatted.
3/27/2019 3:10:09 AM •
Verbatim...
Answered
on Mar 27, 2019
