FixYa.com
BenQ PDP-46W1 46 in. HDTV-Ready Plasma Television
All Products > BenQ > Flat Panel Televisions
Problems with BenQ PDP-46W1 46 in. HDTV-Ready Plasma Television?
Search inside BenQ PDP-46W1 46 in. HDTV-Ready Plasma... Knowledgebase
Troubleshooting and Support
Solved Problems for BenQ PDP-46W1 46 in. HDTV-Ready Plasma Television RSS Feed Post a New Problem
Color fading to black and red...
Our BenQ 46w1 is having problems maintaining optimal color, it fades to black and red "nightvision" type...
1 Solution
Benq Plasma TV
There is a vertical green line down the center of the tv. It is a 46 in Plasma Any thoughts on how to resolve? Doug
1 Solution
red lines and burn in
Can this be fixed or is the tv junk? It has red fuzz at the bottum and a little burn in. This just started today I shut...
1 Solution
no picture
my power button shows green, however I get no picture what so ever. Should I send it to a repairman or will it probably...
1 Solution
remote does'nt work
i have a BanQ 46w1 46in plasma, the remote does'nt work like there is no signal from the remote to the tv, i replace the...
1 Solution
Horizontal lines on lower portion of...
TV worked fine in the morning about seven days ago. At night when I turned the tv on there were about seven black lines...
1 Solution
Monitor goes black - green light stays on
The picture is perfect when the screen is on, but it goes black very shortly after startup, and sometimes goes back on...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ PDP-46W1 46 in. HDTV-Ready Plasma Television RSS Feed Post a New Problem
42" Sansui Plasma Screen problem
After a while +- 5 min the screen starts filing with black and green colors on the plasma. If you power off the screen...
Post a Solution
red line
i have a red line i try to change de board but the line continue
Post a Solution
Benq 46in plasma tv going black screen
TV will power up all the time but will go to a black screen with vertical lines and no picture but with sound as soon as...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size46 inch
Digital TV StandardHDTV-Ready
Flat Panel TypePlasma
Display Resolution852 x 480 pixels
Display Capabilities
Aspect Ratio16:9
Built-in TunerNTSC · PAL · SECAM
Display Format1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote ControlStandard
Image Quality
Contrast Ratio850:1
Comb Filter3DYC / 3D Digital
Pixel Pitch1.182 mm
Brightness700 cd/m²
Output Color16.7 million colors
Viewing Angle160
Audio Features
Audio TypeVirtual Surround
Technical Features
Picture in PictureWith PIP
Connectors
Rear Input ConnectorsComposite x 1 · S-Video x 1 · Component x 1 · DVI x 1 · Audio (RCA) x 2 · 1 x D-Sub (RGB PC) · 1 x RS-232C
Rear Output ConnectorsComposite x 1 · Audio (RCA) x 1
Screen Text
OSD LanguagesEnglish · French · Spanish · German · Italian
Speakers
Number of Speakers2 Speakers
Speaker Power2 x 2.5 Watt
Dimensions
Depth3.86 in.
Height27.2 in.
Width44.8 in.
Weight74.96 lb.
Warranty
Overall Warranty3 Years
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
