20 Most Recent Peavey Scorpion SP1525 Loudspeaker Questions & Answers
I have a 12" Peavey
The voice coil is probably damaged. You can get replacement basket that has the cone, basket, and voice coil for under $100 and put the old magnet on it. Reconing costs as much... you can change the basket in 5 minutes. Sometimes the voice coil partially separates from the cone or you can see it has overheated when you take the magnet off. Be careful not to get contamination in the magnet asembly. The basket is part number SP12825 RB for a 12 inch 8 ohm type..
4/9/2014 9:44:45 PM • Peavey Scorpion... • Answered on Apr 09, 2014
I have the Peavey PV14 mixer, and suddenly the effects will not work. It is not a new board but I have always taken really good care of it! Help!
It sounds like there might be an issue with your audio equipment or settings. Double-check the connections, ensure proper device selection, and verify if your equipment is functioning correctly. If the problem persists, consider seeking technical support or consulting forums for specific troubleshooting advice based on your setup.
1/3/2024 2:06:47 AM • Peavey Music • Answered on Jan 03, 2024
2answers
Peavey 14 bt mixer won't pan. Keeps sending signal to both outputs
If your Peavey 14 BT mixer is not allowing you to pan the audio signal and is sending the same signal to both outputs, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can take to address the problem: 1. **Check the Pan Controls:** Make sure you're using the correct pan controls for the channels you're trying to pan. The pan controls are typically knobs labeled "Pan" or "Balance" on each channel strip. Ensure that they're set to the desired positions. 2. **Reset Pan Controls:** If you've already adjusted the pan controls and they're not working as expected, try resetting them to their center positions. This can help eliminate any accidental settings that might be causing the issue. 3. **Channel Routing:** Some mixers have routing options that can affect panning. Check if there are any routing switches or buttons that might be affecting the signal routing for each channel. 4. **Mono/Stereo Mode:** Some mixers have a mono/stereo mode switch that can affect panning. Make sure the mixer is in the appropriate mode for your setup. 5. **Master Pan Control:** Ensure that the master stereo output pan control is set to the center position. If it's panned to one side, it can affect the overall stereo output. 6. **Test Different Channels:** Try panning different channels to see if the issue is specific to one channel or affecting multiple channels. 7. **Firmware/Software Update:** If your mixer has digital components or software control, check if there are any firmware updates available. Sometimes, software updates can address functionality issues. 8. **Physical Damage or Wear:** Inspect the pan controls and associated circuitry for any physical damage or wear that could be causing the issue. 9. **Factory Reset:** If none of the above steps resolve the issue, you might consider performing a factory reset on the mixer. Be sure to back up any important settings before doing this. 10. **Professional Service:** If the problem persists after trying these steps, it might be a more complex internal issue that requires professional servicing. Contact Peavey's customer support or a qualified audio technician for further assistance. Remember that the exact steps and controls can vary depending on the model of your Peavey mixer. Refer to the user manual for your specific model for more detailed information on troubleshooting and operation.
8/20/2023 2:15:59 PM • Peavey Music • Answered on Aug 20, 2023
Serial number on my Peavey guitar?
My guess is 1985. I think the T-60 was made from 1978 to 1988. I can't find your number in the Peavey finder so I jumped to the following chart where I just rather made up where in might fit. I'm not sure if even peavey can help. https://www.guitarsite.com/database/Guitars/rec/2986/wwwboard/messages/41.shtml https://peavey.com/c/Support
2/24/2023 7:59:30 PM • Peavey Music • Answered on Feb 24, 2023
Does the peavey xr-600b have phantom power
It does not have built-in phantom power. Phantom power is a method used to provide power to condenser microphones and other devices that require a small amount of power to operate. It is important to note that the XR-600B have XLR inputs which are typically used for condenser microphones that require phantom power but it does not provide this feature. If you want to use a condenser microphone with the XR-600B, you'll need an external phantom power supply or an audio interface that provides phantom power.
1/12/2023 8:34:18 PM • Peavey Music • Answered on Jan 12, 2023
Peavey bass R1080052 looking for any info .
Peavey R1080052 is a bass guitar model produced by the Peavey company. It is part of the company's Classic series of instruments, which are designed to offer vintage-inspired tones and aesthetics at an affordable price. The R1080052 features a solid ash body, a maple neck with a rosewood fingerboard, and two single-coil pickups. It also has a vintage-style bridge and a set of open-gear tuners. This bass is known for its warm, punchy sound and comfortable, easy-to-play feel.
1/10/2023 12:11:58 AM • Peavey Music • Answered on Jan 10, 2023
I have a electric Peavey guitar T-15 I and the strings was off when I got it.I was told that I need to put the strings on it to keep the neck from warping,and just snug them up.Is thattrue or not?
No. If you're going to store or display a guitar and not play it, its good practice to slightly ease the tension of the strings to prevent warping. Either way, you'll want to keep moisture and temps in mind to prevent neck warping
1/7/2023 2:44:35 AM • Peavey Music • Answered on Jan 07, 2023
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
8/17/2022 12:30:15 PM • Peavey Music • Answered on Aug 17, 2022
2answers
Looking for the fuse location on a Peavey KB2 amp.??
The back doesn't come off. On the back beside the cord hookup and beside Channel 1 Input are screws. You unscrew the two screws on either side. You then have four screws on the top of the amplifier. Unscrew those four screws and pull them out, six screws in total, then the amplifier will pull right out. You then pull the plug that attaches the speaker to the circuit board off and then you can do any kind of Maintenance or anything you want to the KB2. once inside the fuse is directly beside the heatsink 16580978522326776265122519194431-i0jh5gn5hmrc2jqfnumckiuz-d-0.jpg 16580979322615658009519643158353-i0jh5gn5hmrc2jqfnumckiuz-d-1.jpg 16580979322615658009519643158353-i0jh5gn5hmrc2jqfnumckiuz-d-2.jpg
7/17/2022 10:46:40 PM • Peavey Music • Answered on Jul 17, 2022
1993 Peavey Impact 1 Guitar. Wiring diagram please.
Nothing appears online as far as wiring. There is a wiring diagram on eBay for the Nitro. Here is the manual for your and Peavey contact details on the last page. https://www.manualslib.com/manual/306238/Peavey-Impact-Impact-1.html?page=4#manual Customer Service https://peavey.com/c/Support ..
7/9/2022 5:07:38 PM • Peavey Music • Answered on Jul 09, 2022
2answers
3answers
Peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps. Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
12/11/2021 8:17:54 PM • Peavey Music • Answered on Dec 11, 2021
2answers
Want to know how old my electric Peavey Predator is and how much is it worth? . Serial number: 06829904
Between £60 and £300 depending on condition. Age ... talk to Peavey or a knowledgeable music store.
9/23/2021 9:17:05 AM • Peavey Music • Answered on Sep 23, 2021
Impulse 200p. Why is there no sound output from the horn?
There could be a broken wire connection or a burned out driver. Another possibility is failure in a filter circuit.
9/9/2021 2:11:57 AM • Peavey Music • Answered on Sep 09, 2021
Peavey predator guitar serial $07138985 how old is it worth of it
Serials
Peavey Predator serial numbers - Peavey Forum
forums.peavey.com > Instruments > Peavey Guitars
Aug 20, 2011 - I am looking at a very nice, older Predator. Can someone explain the serial number codes so that I can get an idea of this guitar's age? Peavey list of guitars & years made - Peavey Forum Jul. 13, 2011 predator serial number - Peavey Forum Jul. 1, 2015 Peavey Predator guitar serial number - Peavey Forum Sep. 28, 2010 Freshening up a Peavey Predator? - Peavey Forum Dec. 8, 2013 More results from forums.peavey.com
List of Peavey guitars - Wikipedia
en.wikipedia.org > wiki > List_of_Peavey_guitars
Peavey Guitars are electric, acoustic, and electric bass guitars branded by Peavey Electronics. Contents. 1 List of models. 1.1 Guitars; 1.2 Bass guitars; 1.3 Acoustic guitars; 1.4 Serial numbers ... Predator (Kahler Flyer tremolo made in USA 1985-1988); Predator (Power Bend tremolo made in USA); Predator AX (made in ... ‎List of models · ‎Guitars · ‎Bass guitars · ‎Serial numbers For values, go to eBay and in the filter, put Prices Fetched.
9/1/2021 2:49:34 AM • Peavey Music • Answered on Sep 01, 2021
Peavey Scorpion SP1525 Loudspeaker Logo
1 questions posted
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
View Most Popular
Peavey Music
  • Peavey Music
Most Popular Question
12 peavey
  • Music
