20 Most Recent Lite On LTC-48161H CD-RW/DVD-ROM Burner Questions & Answers
what problem it have exactly?if it cant bring out correctly,its depend on the lever & inside motor of it.sometimes must change a plastic part that move the lever in & out by motor.
Lite On... | Answered on Jun 15, 2013
There is no need to install any software before/after connecting the LiteOn device,
because Windows XP/Vista/7 already contain the necessary device-drivers.
So, just connect it, and restart Windows, and it will be ready-to-use.
Windows Media Player can be used to play DVD-movies,
and Windows has built-in software to write onto CD-recordable disks.
Lite On... | Answered on Feb 19, 2011
In that case the infrared laser - the one for the cd - is dead and this is unfixable.
Time for a new dvd-rw unit, it's just $30.
Lite On... | Answered on Sep 30, 2010
i would try running a cd/dvd cleaning cd in it first. (availabe at most retail electronic stores)
then i would try downloading the latest firmware (software that programs the drive for cd/dvd formats) from your cd/dvd manufacturers website and installing it, making sure it is correct for your model cd/dvd hardware.
if it doesn't read ANY discs then it may need replacing and you can order it online for 40 bucks or less.
Regards
Lite On... | Answered on Aug 09, 2010
is it reading a disc??
if it is neither reading nor burning any disc...upgrade the firmware of the drive
Lite On... | Answered on Jul 29, 2010
You need to purchase a 5.25" external enclosure with the same connection type as your drive (which is IDE). You install your drive into that enclosure and then use the drive via USB. The enclosure will have all the cables you'll need. I recommend this one = http://www.newegg.com/Product/Product.aspx?Item=N82E16817145050
Lite On... | Answered on Feb 20, 2010
Hello
Ok, usually you do not need to install drivier, just plug it in.
It is a plug and play device. Are you looking for the software to operate this device?
At the link below you will be able to to download burning software.
http://www.nero.com/eng/downloads-nero9-free.php
Once at the site, just fill in your email, so the link will be activated.
If this was not what you were looking for, let me know so i can help you.
Kind regards
Andrea
Lite On... | Answered on Jan 04, 2010
The "paperclip trick" should work - try doing it with the power to the PC off next time. You may have to angle the clip a little left, right up or down to find the point that needs to be pushed. Each time you pull out and push in the tray will move outward. - repeat as needed to remove the disk from the tray.
Power up the computer and gently push the tray in manually. It make not eject w/ the button or software command until the next power down / power up cycle, and then it should return to working as expected.
Lite On... | Answered on Oct 02, 2009
because its probubly not formated.
Lite On... | Answered on Aug 14, 2009
do you have the software that recognise DVD? never show you a dvd?
Lite On... | Answered on Dec 03, 2008
It only support DVD read and CD-RW check this link for the complete information about this combo drive http://www.dealtime.co.uk/xPF-Liteon-LTC-48161H
Hope that helps.........
Lite On... | Answered on Jul 23, 2008
Yes. DVD drives are intercompatable for the most part.these days. just pull out the old one, install the new one, and the OS will install the drivers and it will work just fine.
Lite On... | Answered on Jul 11, 2019
In case you have a good PC, you can easily install it using Bluestacks. Here are the steps:
  1. Download Bluestacks
  2. Search for "GDMSS Lite"
  3. Proceed with installation.
Source: Download gDMSS Lite for PC on Windows 7 8 or 10 10Downloads com
Lite On... | Answered on Oct 02, 2018
Rule number 1 in pc troubleshooting and electronic troubleshooting is to always power down the device and turn it back on to see if that doesn't help, if the problem persists. . . you can call us on your fixya app and we can help you fix your issue with no problem. Hope this helps ??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brant_4c68df22dda524c2
Lite On... | Answered on Sep 21, 2017
Most power supplies have a fuse in them. That is most likely the problem. Otherwise, if you open them up, you can see which capacitor has gone bad, 'cause they will have obviously ruptured.
Lite On... | Answered on Apr 12, 2016
Lite On LTC-48161H CD-RW/DVD-ROM Burner Logo
Popular Tags
17 questions posted
Top Lite On Computers & Internet Experts
Pierre Laplante
Ekse
Damen Wong
Damen Wong
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Computers & Internet
Most Popular Question
writing dvds
  • Computers & Internet
