20 Most Recent Fujitsu Plasmavision 42" TV Questions & Answers
First place to look is the power supply inside the set, look for damage or puffed up filter caps.
Fujitsu... | Answered on May 10, 2016
Yes, the P42XTA51U has an ATSC (digital OTA) tuner. This is given in the specifications for the Fujitsu 51 Series TVs. That document is available here: http://www.hdtvsolutions.com/Fujitsu-P63XTA51US.htm . The direct link to the specifications sheet is http://www.hdtvsolutions.com/pdf/ht_tuner_brochure.pdf . Fujitsu had to include an ATSC tuner because the TV was manufactured in 2005. U.S. law required TVs over 36" have an ATSC tuner starting in 2005.
If you use the appropriate antenna, you'll be able to watch OTA broadcasts. I recommend checking with TVfool.com for antenna suggestions and the angle between your location and the transmitters. ( antennaweb.org assumes an external antenna but is very conservative in the list of available stations.)
I hope this helps.
Fujitsu... | Answered on Oct 30, 2015
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Fujitsu... | Answered on Jun 30, 2015
you may use a channel converter to your TV, you can connect it to AV input just like using DVD player and you can watch TV programs by using it.
Fujitsu... | Answered on Oct 04, 2014
What is the problem you faces with this Plasma TV? Provide more details, please. Gopakumar Gopalan Google
Fujitsu... | Answered on Feb 19, 2014
Up , i also encountered the same problem 3 days ago. 42" Fujitsu Plasmavission. I'll try to call an expert, i hope its not a digital board again for me, it will cost around $2,000usd so better buy a new Korean made LCD for better and cheaper parts. I guess you also experiencing trmendous heat at the back of your plasma right?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Fujitsu... | Answered on Feb 18, 2014
Fujitsu Plasmavision 42" TV Logo
131 questions posted
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Fujitsu Televison & Video
Most Popular Question
fujitsu p42xta51 fujitsu atsc tuning
  • Televison & Video
