20 Most Recent
Toshiba Satellite C655-S5082 Laptop Questions & Answers
I bought a brand new Toshiba Satellite C655, I
Ran into this 1 before a few times on the 600 series Cs, once was a driver issue from a virus left unrepaired and the second time was a bios error which required me to obtain the bios update and reflash the bios, not an easy project at all, but watch the youtube how to videos and im sure you could handle it :).
11/8/2017 1:53:09 PM •
Toshiba...
Answered
on Nov 08, 2017
The charger for the the
Using a volt meter check the output of your adapter. If not within specs it is no good.
8/29/2017 1:10:35 PM •
Toshiba...
Answered
on Aug 29, 2017
Lg pairing
What lg device is it that you're trying to pair with the laptop?
8/4/2014 2:31:04 AM •
Toshiba...
Answered
on Aug 04, 2014
Can you install a printer to satellite C655
Of course, if you have the software or are able to find the correct drivers that are compatible with your Operating System. You need touse a USB cable, or an Ethernet cable. If it has wireless communication capabilities then you can also connect it to the computer through the wireless.
10/20/2013 2:46:36 AM •
Toshiba...
Answered
on Oct 20, 2013
Driver
First, you have to turn on the wireless switch - Try to power on the wireless by pressing FN+F8 together2.If its already turned on but disabled than you have to enable it:-
Second, in the task bar, click on the local area connection icon ==> wireless network connection ==>enable
if you do not know the local area connection icon, try to pass your mouse over icons in the task bar, and read the labelsORor go to start>>control panel>network connection>right click on wireless network connection and left click on enable.I hope this will be helpful for you. please mark the solution if it was helpful. also let me know if still issue persist.Regards,sunil kumar
5/16/2013 11:06:52 AM •
Toshiba...
Answered
on May 16, 2013
Toshiba locked
It isn't the government. It is a SCAM!Even if you pay the extortion money, nothing changes.I received this information from another expert, in an alike problem.The solution is to remove the internet access to the computer.Then put the Restoration disk in your optical drive. (CD/DVD drive)When asked choose Full Install. Destructive Installation.The computer will go back to day 1 from the factory.ALL personal information will be lost.ALL installed, or downloaded programs, will be lost.Regards,joecoolvette
5/13/2013 8:27:59 AM •
Toshiba...
Answered
on May 13, 2013
How to hook up my toshiba c655 to tv and have audio
If you have HDMI out on your laptop, it should send the sound and picture to your TV (make sure appropriate drivers are installed). If you only have VGA out, then it will not send sound. Tthe only other option is if your TV has Audio IN (either 3.5mm headphone jack, or RCA Left/Right), then you could connect the headphone jack of your laptop to the TV that way.
6/19/2012 9:29:07 PM •
Toshiba...
Answered
on Jun 19, 2012
I was letting my son
Most of the time, the bios password can not be reset unless you pull out the CMOS battery and do a reset switch.
Shortly, you will need to bring it to someone if you aren't comfortable opening the laptop. If you are comfortable, open it up, remove all the screws and pieces and then when you get to the motherboard (big green thing with a bunch of electronic looking things soldered to it), find a battery that looks like a watch battery. Carefully remove it and let it sit for at least 24 hours (with no other power sources connected) and that should clear it out.
3/23/2011 2:57:27 PM •
Toshiba...
Answered
on Mar 23, 2011
